Cutting 45 degree angles in t-molding
Postby suckerpunched » Mon Aug 09, 2010 6:22 pm
Hey all,
I'm ready to cut the t-molding to frame the doors....How have you all cut yours????? I tried a mitre box and hacksaw and got the first cut but it's pretty iffy on making the second cut the right length. Only have enough to do it once so looking for some experienced advice.....
Thanks,,,,TC
If you see my harley on a trailer,,,,call the police cause it's being stolen...
suckerpunched
Images: 22
Postby Gage » Mon Aug 09, 2010 7:36 pm
Just take your time and be sure of your dimensions. (and use the mitre box) ;)
Image Image Image
Gage
Images: 28
Postby David S » Mon Aug 09, 2010 7:38 pm
Take a peice of wood,cut a slot in it length ways for the T molding to set in. This will keep the molding flat and square, then cut it on a miter saw with a carbide tip blade.
Oh and don't forget the most important part, "always wear your saftey glasses"
Good luck!!
David S
Images: 53
Postby doug hodder » Tue Aug 10, 2010 9:59 am
Something I do on things like that....cut it long, like 1/4". Then go to the stationary disk sander with a 45 degree jig or gauge and sand in the last 1/4" to fit exactly, go back and forth checking till you get it where you want. Does require an extra tool however. For just cutting on the chop saw or in a miter box. I'd make up a piece of wood to cradle the molding and support the "tongue" on it. Helps to keep from hanging up and kinking the ends, like mentioned above. Doug
Postby asianflava » Tue Aug 10, 2010 11:39 am
Because I was in a time crunch, I bought a horizontal metal cutting bandsaw just for this. I used it to cut all my trim. It happened to be on sale plus I had a coupon so it wasn't terribly expensive.
That thing has saved me on a few occasions now. I'm not saying to go out and buy one, but that's what I did. If you can find someone to borrow one from, even better.
asianflava
Postby suckerpunched » Mon Aug 23, 2010 3:38 pm
Thanks for the tips.....ended up using the mitre box and hacksaw, clamping the molding between 1x2s to hold steady....worked well
TC :)
suckerpunched
Images: 22
