Should I waterproof the floor and sidewalls inside and out and if so what should I use? I'm gonna use aluminum for the outer skin. Thanks in advance.--------Larry
I'm either gonna use 3/8" or 1/2" acx plywood. I may have to use 3/8" because I ended up making my floor framing 47-3/16" wide. I'm making a 4x8 trailer.
I've used regular enamel latex paint under mine when I skinned over with aluminum. Had plenty just laying around - needing to be used - didn't really matter about the color 'caus I was covering it up anyways.
