Page 1 of 2
herculiner use???
PostPosted: Thu Jun 30, 2005 3:21 pm
by cguardsman
As i am new to this site and trying to collect ideas before starting my build has any one tried using herculiner for their roof covering??? :thinking: also..has anyone tried one of the portable a/c units that can be moved from room to room in a home??
PostPosted: Thu Jun 30, 2005 3:24 pm
by toypusher
Look at some of the pics from Minden, there is a blue teardrop that is totally covered tin Rhioliner. It looks great.
I have a Maytag 'freestanding' A/C at home that does not have a resevoir to empty, but it is quite heavy and combursome. I don't think that it would work well in a teardrop.
Kerry
PostPosted: Thu Jun 30, 2005 3:31 pm
by cguardsman
i saw the rinoliner tear and thought that one could probably use herculiner only for the roof of it but, have never worked with the herculiner and wanted an experienced opinion if there were any here....as far as the a/c units i have seen several that were fairly light and had the capacity to drain through a hose.....like i said just trying to figure things out ahead of time ;)
PostPosted: Thu Jun 30, 2005 4:03 pm
by Ken A Hood
Here's a similiar product. I'm waiting on more info from them. Looking at the multiple uses, it looks almost bullet-proof...
LINK
PostPosted: Thu Jun 30, 2005 4:13 pm
by gman
The do it yourself (Herculiner) comes in black only, the have it sprayed on (Rhino) stuff if very expensive, I got a quote of $600 to do the inside walls and floor of my 6'x 54" pickup box, about the same area as the roof of the tear. Color was another $100.
PostPosted: Thu Jun 30, 2005 4:23 pm
by Ken A Hood
The Durabak product comes in several colors, has rough and smooth textures available, AND can be order with added UV protection....
It weighs only 10lb/gallon as well, and 1 gallon covers approx. 60sq. ft.
FACT SHEET
PostPosted: Thu Jun 30, 2005 4:47 pm
by cguardsman
gman wrote:The do it yourself (Herculiner) comes in black only, the have it sprayed on (Rhino) stuff if very expensive, I got a quote of $600 to do the inside walls and floor of my 6'x 54" pickup box, about the same area as the roof of the tear. Color was another $100.
herculiner site also lists white and grey.......line-x and rinoliner are way high and i want something i can do myself. i really liked the look of the one in the photos from Minden.
PostPosted: Fri Jul 01, 2005 1:27 am
by dahoon
I have been to that side of the mountain.
I used Herculiner on my pick up box. Two things to avoid: 1) direct sunlight & 2) below 80 degrees gives you more working time.
I also sell Herculiner. It would work great for a roof material. It comes in three colors: Black, Grey and White. the two latter colors are fairly new.
The gallon kit will run you around $100 +/- and comes with a tray, roller, gloves, etc.
It also comes in quarts for $30 +/-. And those are seprate not in a kit.
If your surface is clean and dry it seems to stick to everything. I had let it wear off my hands and its held up well in my truck too.
PostPosted: Fri Jul 01, 2005 1:48 am
by madjack
...as for A/C have you seen the PET COOL
madjack 8)
PostPosted: Fri Jul 01, 2005 7:39 am
by IraRat
Ken A Hood wrote:The Durabak product comes in several colors, has rough and smooth textures available, AND can be order with added UV protection....
FACT SHEET
That stuff looks great as a covering for the sides too--not just for the roof. An alternative to Uniflex?? I think Durabak's rough coating may be great to hide any surface imperfections, whereas with Uniflex, I think you need a really smooth, perfect surface, since it'll show everything.
PostPosted: Fri Jul 01, 2005 9:14 am
by cguardsman
madjack wrote:...as for A/C have you seen the PET COOL
madjack 8)
yes i have looked at the pet kool site and am impressed but not $400 impressed! :shock: i am looking for a more low buck alternative i do like the way you can duct the pet kool in though!
PostPosted: Fri Jul 01, 2005 9:16 am
by cguardsman
FACT SHEET
it looks as though the durabak comes in a smooth type too!
PostPosted: Sun Jul 03, 2005 1:31 pm
by Guest
Dahoon,
I finally saw a commercial about Herculiner...
I've had a bad experience with powder coating... I'm currently "advertising" for a local powder coating company that didn't want to correct a bad powder coating job on my glass racks... I figure I've got about another year before rust gets the best of my glass racks and I have to replace them...
Do you think Herculiner would work as a good coating to protect the frame?
PostPosted: Sun Jul 03, 2005 3:46 pm
by WoodSmith
Dean in Eureka, CA wrote:Dahoon,
I would not use herculiner personally. Here's my story:
I bought a new F150 in July of 99, shortly thereafter I paid (I think) $400 to have a Line-X liner sprayed in. I LOVE it. I've had firewood, 8' long 20" diameter cedar logs, mulch, you name it, in there and there is not one place where it has worn through. I think there is one place where I managed to dig a shovel point into it and took out a small chip, I've spilled some paint on it during a dump run that hasn't come off, It has faded a little bit, but otherwise it looks and performs as well now as it did almost 6 years ago when it was brandy new.
On the other hand, my neighbor up the street bought a used Dakota pickup a couple years later. He and his FIL decided they would use Herculiner to protect his bed. They applied it per the instructions (as far as I know, I wasn't there). He uses his truck more as a commuter and less as a hauler. Both trucks are parked outside, on the same side of the street with virtually no shade. You can see the white paint showing through his liner in a LOT of different places. Even on the sidewalls inside the bed where you would not expect wear. He has called the company and they are sending him some more to reapply.
I don't know how well either job was preped as I didn't watch either of them. But I can say without hesitation that my Line-X has taken more abuse for a longer time and looks beter than his Herculiner.
PostPosted: Sun Jul 03, 2005 4:34 pm
by asianflava
I didn't want to post any negative posts about Herculiner until someone with first hand experience did. I don't have any first hand experience with Herculiner, just stories from others who have.
The conclusion I came to was that the DIY stuff is no where as good as Line-X and Rhino. I know people who have had Line-X and Rhino in their trucks for years.
