LDK wrote:I have a router but I don't have alot of experience with it.
This thread has a lot of good advice for you. Follow it and you should be fine.
planovet: Top or bottom bearing bit, either one will work
madjack: The important part is to be confident in your ability with the router...if not, more
practice should be done, since a router can do more harm faster, than a sudden sneeze or eye blink
tonyj: I would bandsaw or jigsaw cut the piece even closer to the line, maybe an 1/8 or 1/16 inch. The less the router bit has to take off, the less of a chance for a little oops.
aggie79: 1. Spend the money to get carbide tipped bits rather than steel bits. 2. The direction of the cut or the way you move your router is important. A router spins the bits clockwise. You want move the router so that the cut helps "pull" the router to the part being cut. If you're cutting on the outside of the template, then you move your router from left to right.
