Building to store outside
Postby Kelleyaynn » Tue Oct 05, 2010 11:58 am
I have to store my teardrop outside, not under cover other than a UV/water resistant cloth cover (but not a dropcloth!). Would fiberglassing the sides help? I think covering the whole thing (not just the roof) with aluminum would be best, but my husband wants wood sides -doesn't like the all aluminum look nearly as much. So I'm trying to find out what I can do to weatherproof the sides as best as possible. Perhaps marine grade epoxy/sealant, but I'm thinking fiberglass might be even better.
Doing a search didn't really answer my question.
Kelleyaynn
Postby grant whipp » Tue Oct 05, 2010 12:45 pm
If your husband wants the woody look, seal it all up with about 3 coats of clear epoxy, then spray that with about 3 coats of clear automotive enamel or urethane ... just fiberglass or epoxy do not have UV shielding, that's why you need the automotive clear over them. Check out any of Dough Hodder's builds, or Steve Frederickson's, or several other's, and you'll see what I mean.
Good Luck, and as always ...
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
Postby cracker39 » Sun Oct 17, 2010 2:51 pm
But, if you're painting it...
As I posted in two other topics already today, The Squidget's paint is still holding up well after nearly 5 years (per phone report to me recently by the guy who bought it two years ago). The plywood was coated with fiberglass epoxy resin (two or three coats on the edges), then primed and painted (Zinsser 123 primer, Glidden latex porch and deck enamel).
Dale
cracker39
Images: 233
Postby Off Grid Rving » Tue Oct 19, 2010 2:49 pm
I am loving my herculiner exterior and floor inside! this thing feels built like a tank. I could probably float down a river in it too heh.
Check out http://offgridrving.com
--Update--
http://offgridrving.com has been transformed into Community Sites - where you can sign up for your very own project site, chronicle your experiences on the journey at http://offgridrving.com
Get your own space to post updates and pictures and even videos of your build.
Off Grid Rving
Postby caseydog » Tue Oct 19, 2010 4:10 pm
MaryK in Florida built a cool structure for her woody. I think there is a build thread for it, but I can't find it.
The walls are built like a fence, so air can circulate, and it has a rood and gate, so it is out of the sun and weather.
I'll keep looking for it. Maybe someone else knows where it is. :thinking:
CD
My build journal is HERE
caseydog
Images: 515
Postby mikeschn » Tue Oct 19, 2010 4:19 pm
My next build is going to be aluminum. It think it weathers better than wood.
However, if you must do wood, check out what the kayak builders do!
