Window gasket question
I just received a window from eBay. It has an attached rubber gasket where most folks would use butyl tape or silicone.
I am planning to use this as a sunroof and am very paranoid about leaks. Since this is a used window and I can't be 100% sure about the quality of the rubber, should I remove the rubber & seal with tape or silicone? Leave the rubber and use tape/silicone too?
Thanks for the help!
