Where do you get that pink insulation?
Postby Kelleyaynn » Sun Oct 17, 2010 3:40 pm
I could swear I've read that you can buy the pink (sometimes blue or green) foam insulation in the big box stores. But I've checked both Lowe's and Home Depot, and all they have are some white styrofoam sheets.
Kelleyaynn
Postby CAJUN LADY » Sun Oct 17, 2010 4:00 pm
Lowe's had some of the silver backed insulation but it could vary from store to store.
Becca
~Cajun Lady~
CAJUN LADY
Images: 74
Postby jss06 » Sun Oct 17, 2010 4:14 pm
It's available at Lowe's and Home Depot here in Dallas.
jss06
Palladium Donating Member
Postby bobhenry » Sun Oct 17, 2010 5:14 pm
Here is 2" , 1" and 3/4" skews they should have 1/2" as well.
These products are in the yard ask for it at the lumber order desk
http://www.lowes.com/ProductDisplay?partNumber=14541-46086-133909&langId=-1&storeId=10151&productId=3110651&catalogId=10051&cmRelshp=sim&rel=nofollow&cId=PDIO1
Postby pete.wilson » Sun Oct 17, 2010 5:20 pm
Hey
Whenb I was in Kansas, I could buy foam board in 3/4" up to 2" but here in VA. all I can find is 3/4" only. I can get white styrofoam in 1" but don't want that. Maybe it's a midwest/north thing for getting the thicker sizes.
Pete Wilson
Why hasn't anyone found a dead bigfoot? When was the last time you found a dead deer, bear, coyote, fox, squirrel, etc. that died in the woods.........Hmmm.
pete.wilson
Postby H-Balm » Sun Oct 17, 2010 6:49 pm
Just ask.... they should certainly be able to get you some.
H-Balm
Postby Nosty » Tue Oct 19, 2010 12:38 pm
Hi Kelleyaynn,
If they don't have it in the store, they can almost always order it for you, (Lowes and Home Depot).
I used some of the pink and some of the foil backed white, (1") in mine and found that the foil backed is a lot easier to work with. The pink has a cellophane film on one side that peals off sometimes when you're cutting it.
Good luck,
Brian
"I'm not talking to myself; I'm conversing with one of the myriad of voices in my head!"
View my build blog: http://www.briangreenleaf.wordpress.com
Visit my website:
http://www.bgreenleaf.com
Nosty
Images: 41
Postby PrivateerEn96 » Thu Oct 28, 2010 8:48 pm
I'm new at this and ready to insulate the floor of my Cubby. I bought the styrofoam stuff because I couldn't find the the pink/green/blue foam board either.
Do y'all advise using the styrofoam stuff?
PrivateerEn96
Postby Kelleyaynn » Fri Oct 29, 2010 8:47 am
I did manage to find some of the blue stuff at my local Lowe's - in a different aisle than is labeled "insulation". Go figure. Thanks for your help.
Kelleyaynn
Postby cracker39 » Sun Oct 31, 2010 3:08 pm
CAJUN LADY wrote:Lowe's had some of the silver backed insulation but it could vary from store to store.
Does it ever. One Lowes here in my area has the 1/2" blue Dow foam sheets that I use for model airboats, but another Lowes doesn't carry it. Same with Home Depot. One store will have an item that another store doesn't carry. Go Figure. I find the paper/foil backed 3/4" foam sheets at my local HD for trailer insulating.
Dale
cracker39
Images: 233
