Plastic or tyvek?
Plastic or tyvek?
Postby Wimperdink » Tue Oct 19, 2010 6:22 pm
Just a quick question. I am rebuilding a 1962 or 64? Aloha canned ham trailer. I'm still in the process of insulating. I intend to cover this with some type of moisture barrier before putting the tin back up. Would you recommend using plastic sheeting or tyvek? Plastic I have, Tyvek I don't.
Wimperdink
Images: 33
Postby 48Rob » Wed Oct 20, 2010 6:03 am
Vapor barrier would go on the inside, between the paneling and insulation
(unless you are in an extremely dry, hot climate where the inside of the trailer is always air conditioned).
Tn. doesn't qualify...
If you have to put something on the outside, Tyvec is a much better choice than plastic, as it will allow trapped moisture to get out of the wall cavities.
If you put plastic on the outside, it can trap the moisture, causing more rot and mold problems.
Rob
48Rob
Postby Wimperdink » Wed Oct 20, 2010 12:05 pm
good point.... I was hoping that if there were any future leaks like what caused the need for this rebuild in the first place, that it would just roll off and down on the moisture barrier before touching wood. The windows in this trailer are the glass slats that don't seal worth a hoot so ventilation isn't an issue anyway.
Wimperdink
Images: 33
Postby cracker39 » Sun Oct 24, 2010 11:05 am
48Rob wrote:Vapor barrier would go on the inside, between the paneling and insulation
Rob
Both here in Florida and in Maryland and Virginia (while I lived there), I've seen Tyvek installed on the outside of the framed walls before the siding went on.
Examples. I Googled "Photos Tyvek Installed" and they all look like these.
http://www.homesforourtroops.org/images/content/photos/large_16150.jpg
http://www.dflyonsconstruction.com/images/Tyvek_house_wrap.jpg
http://www.renaissancerestorations.com/portfolio/nharwood/nsiding1.jpg
http://www.bannisterhousetexas.com/images/P4270511_lg.jpg
http://www.kc0qir.com/blog/gallery/1/PC030033.JPG
Dale
cracker39
Images: 233
Postby 48Rob » Sun Oct 24, 2010 5:55 pm
Dale,
I might be misunderstanding the reason you quoted part of my post?
Tyvec is not a vapor barrier, but plastic is.
The vapor barrier in normal climates goes inside the home, between the insulation and studs/framing to prevent the interior moisture from going through the insulation and or cavities and condensing on the back of the exterior wall.
Tyvec is designed to slow water and air penetration into the home past the siding.
Tyvec "breathes" that is, it allows moisture vapor through, but not heavy moisture like rain.
People in many states use it for that purpose, but it does not replace a moisture barrier, which does not allow anything, water vapor or air movement.
In some hot and humid states, builders may or may not choose to install a vapor barrier, due to concerns that there is just so much humidity in the air, that it is better to let the breeze "blow through the wall".
But in those cases, even Tyvec should be avoided as it will slow moisture release from wall cavities.
If I misunderstood your intent, I'm sorry.
Rob
48Rob
Postby cracker39 » Sun Oct 24, 2010 6:43 pm
OK Rob, I probably did misunderstand. Yep, vapor barriers do go on thie inside of the wall. Sorry if I missed the point.
Dale
cracker39
Images: 233
Postby 48Rob » Mon Oct 25, 2010 6:49 am
Thanks Dale, I wasn't mad, just wanted to clarify.
:shake hands:
Rob
48Rob
Postby Wimperdink » Tue Oct 26, 2010 6:38 pm
Just for sake of conversation, I went with your original post Rob and the tin is back on with nothing between the tin and the studs... My final deciding factor was that it was great like that for the first 50 years.... I'd be happy with 20 more. :)
Wimperdink
Images: 33
Postby Off Grid Rving » Mon Nov 01, 2010 10:37 am
all this talk about tyvek.... any idea where I can get some tyvek scraps. I am need to sew a shell for my flip over ice shanty that im building for this winter. and I dont need a 100 dollar roll of tyvek heh
Check out http://offgridrving.com
--Update--
http://offgridrving.com has been transformed into Community Sites - where you can sign up for your very own project site, chronicle your experiences on the journey at http://offgridrving.com
Get your own space to post updates and pictures and even videos of your build.
Off Grid Rving
Postby halfdome, Danny » Mon Nov 01, 2010 11:54 am
Off Grid Rving wrote:all this talk about tyvek.... any idea where I can get some tyvek scraps. I am need to sew a shell for my flip over ice shanty that im building for this winter. and I dont need a 100 dollar roll of tyvek heh
Tyvek comes in 36" rolls (cheaper for a small job) and can be seamed with Tyvek tape. I did this on our home this summer. Easier to handle for one person. I screwed a closet pole to the building and rolled off the Tyvek like a large roll of paper towels. Very easy by yourself. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
