I'm a first time builder and have been following the two threads dealing with lightweight walls and thrifty coverings. I'm planning on making a TTT. The outside dimensions will be 56" wide x 96"long and 51" high. Inside will be 54" wide by 94" long by 48" high.
I'd like to make the floor from 1/4" luan with sandwiched 1-1/2" rigid foam insulation. Can you get luan in 10' lenghts? I'm planning to frame the sandwich with 2x2 and use 1x2 for corner braces. I'll use a 2x2 for joining the two pieces of luan making up the outer skins. My trailer is 48" wide and I want to make the floor 56" wide to accomodate a full matress and 1" walls. [The walls and ceiling will be 1/8" luan over 3/4" rigid foam with 1x2 framing and bracing.] This will give me a 3" cantilever on each side. Will this be a problem? The walls will fit over a 1x2 I've screwed to the floor. This 1x2 will serve as the bottom part of the frame for the wall sandwich. Will use similar technique to attach ceiling. I think this will give me good strength and rigidity yet light weight. What have I overlooked? I am assuming that it is fairly easy to get casing material for doors and windows that will wrap the 1" walls. Is this true?
I'm planning on using the 25/75 waterproofing on all wood parts. Do I need to coat the bottom of the floor additionally? What is a good product to use? I like the cloth and T2 outer covering idea. Should this be applied first before the bottom coating is applied?
I'm a screw and glue kind of guy so I'm planning on using white glue on all wood parts and then screws. Is there a better option? Really like the beeswax idea. Is T2 the right glue to use on the rigid foam?
Should wiring be installed in the walls before applying top luan skin or should surface wiring be used?
What questions should I have asked but I don't know enough to ask yet?
