Page 1 of 2
Waste Water Planning
Posted:
Wed Oct 20, 2010 11:14 am
by BotDoc
Hello all, I am in the beginning stages of building a teardrop. I have the trailer built but before I go to much farther I want to try and figure out what to do with the waste watter from the sink. What do you all do? Since space is already limited I was thinking of putting a grey water tank mounted to the trailer.
Cheers,
Re: Waste Water Planning
Posted:
Wed Oct 20, 2010 1:02 pm
by GeoDrop
Steve,
I am planning on just running a hose into a bucket. I built a sink drawer that slides out, so the bucket can just sit right there and when we are ready to leave, we can just take it where it needs to go.
I did seriously consider a grey water tank but didn't have a lot of room and then you'd have to plumb it and figure out how to drain it, etc. I still have a small spot for it if I change my mind.
I think most people do mount them under the trailer. You can buy the black ABS ones. Someone even used a bunch of PVC pipe to create one.
BotDoc wrote:Hello all, I am in the beginning stages of building a teardrop. I have the trailer built but before I go to much farther I want to try and figure out what to do with the waste watter from the sink. What do you all do? Since space is already limited I was thinking of putting a grey water tank mounted to the trailer.
Cheers,
Posted:
Wed Oct 20, 2010 1:15 pm
by Arne
sink?
I wash in a pot and throw it on the ground... All is biodegradable and small quantities.. less than 2 quarts.
Posted:
Wed Oct 20, 2010 5:13 pm
by Shadow Catcher
We have a 16 gal gray water tank under the tear.
Posted:
Wed Oct 20, 2010 10:10 pm
by PhotoGuy
Cheers,
I am planning my first build. And since I will be spending most of my time off road, off the grid I will need to carry fresh water. I am planning to build in a gray water tank in mine. Not a lot of room. But it will work.
Posted:
Wed Oct 20, 2010 10:56 pm
by doug hodder
I'd just catch it and dump it on a needy bush, or if in a developed site, there may or may not be a place to dump it, there are lots of "green" detergents available. Detergents will break down hard soil and allow it to absorb more water. I always wipe out the pans first so that there isn't any food that might attract critters however.
As far as a gray water tank on an off road rig...why bother? What are you going to do with your crap and TP?, unless you are planning on a black water tank as well. Chances are...some gray water is going to be a lot less of an environmental issue than whatever you leave on the ground, buried or not. Doug
Posted:
Wed Oct 20, 2010 11:10 pm
by Ageless
While I was in the planning stages of my last trip; I came upon some campgrounds that listed very specific rules. Several specified that dumping of ANY water on the ground was prohibited.
I carry (2) 10 quart buckets for washing/rinsing and a 5 gal. waste water bucket. I do have a connection on the trailer for draining the sink to a sewer line.
While dry camping, I will dispose of 'grey water' to a dug hole if needed.
A bit of research into where you plan to camp is essential.
Posted:
Wed Oct 20, 2010 11:34 pm
by Gage
You can get a Gray Water tank at any RV Store. Picture shows mine under my tear.
Posted:
Thu Oct 21, 2010 3:29 pm
by Wimperdink
Sink? I use a brand new never used for chemicals, chemical sprayer. I walk away from the tear off into nature and do my rinsing away. If in a campground, a bathroom suffices.
I even put a tire valve stem in the bottle so that If i'm lazy, I can pressurize it with an emergancy tire inflater. Of course common sense would say not to let it pressurize above a couple of psi if you use this method.
Posted:
Fri Oct 22, 2010 7:49 am
by GPW
We've got paper plates and plastic cups ,green soap and Vinegar for cleaning ... paper towels ... shouldn't generate much gray water... Good Bucket for that if needed ... Not very Green , but probably no worse than dumping lots of gray water on the plants , or worse, the exhaust fumes from the Tow vehicle ...
Seems like any campground specifically forbidding water dumping would provide a place for this ...
Posted:
Fri Oct 22, 2010 8:38 am
by bobhenry
Nonbreakable plates and cups.
Real soap and real water and an honest to God dishtowel. A bucket to contain the wash water to be dumped in the vault toilet or I have been known to calm down a pesky campfire by pouring it around the outside edge of the fire. Mr. Ranger has never questioned me while trying to control the fire
(Whether it needed it or not)
The food in the waste water is the park staff's concern it can draw unwanted visitors to your campsite. The wood ash in the fire pit seems to render the food particals "Uninteresting" to the critters after it is poured into the pit.
I like real dinnerware and simply detest paper plates. My little Ingrid party ball stores so compact and is so handy and best of all it is colorful.
Posted:
Fri Oct 22, 2010 9:27 am
by GPW
BH, that's a really Nice setup you have there!!!
Very GREEN !!!! ... and yellow and blue and red...
Posted:
Fri Oct 22, 2010 9:30 am
by bobhenry
GPW wrote:BH, that's a really Nice setup you have there!!!
with orange and white for backups
There is one on E-bay today at one cent with no reserve.
http://cgi.ebay.com/Vintage-INGRID-27pc-Plastic-Party-Picnic-Ball-Set-NR-/120636565477?pt=LH_DefaultDomain_0&hash=item1c167fe7e5
And now back to our regular scheduled programing " Waste water planning "
Well if ya didn't have dishes ya wouldnt have waste dish water
Posted:
Mon Oct 25, 2010 9:20 pm
by bdosborn
We use the blue portable tank too. Some places don't allow you to dump greywater, no matter how clean it is (just makes me sneakier
Posted:
Mon Nov 22, 2010 5:56 pm
by droid_ca
some good ideas does anyone ever use a screen to filter out unwanted particles
