For all you hot weather guys, with AC, do I have to go 1 and 1/2 inches on the roof insulation?
I'm a little concerned about not kerfing the two pieces just right, whereas I would have uneven bulges that will rise above the spar heights. I'll be kerfing with a blade.
Will the earth stop rotating on its axis and will mountains fly into space if I can find a sheet of 1" and just use that? Or will that 1/2" of void hurt the whole insulation formula that I'm sure a lot of you guys can recite?
Finally, am I just being paranoid about the difficulty of inserting these 2 panels to curve to the interior roof line and come flush with the top of the spars?
