HELP..old protective plastic baked on alum???
Postby Brock » Sat Nov 06, 2010 5:51 pm
It seems in an effort to protect my alum. skin...I might have ruined the skin finish..I bought alum skin with that clear pvc protective plastic on it and left it on for the last few months thinking it would help keep the exteiror skin from getting scrathed while I worked on the inside,and when I went to peel it off today, it would not come off...It seems to have baked on in the sun...What can I do to remove it??? :x Any help or ideas are welcome PLEASE!!
Brock
Postby Ageless » Sat Nov 06, 2010 6:29 pm
Had that problem many times working for Boeing. If you can get an edge started; drizzle a bit of naptha between the plastic and AL. It's slow, but it works to dissolve the adhesive.
Ageless
Postby Classic Finn » Sun Nov 07, 2010 2:19 pm
Brock I had a similar issue with our as well and I used a hair dryer to get it off. Time consuming but I got it off. :thumbsup:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Brock » Sun Nov 07, 2010 8:07 pm
thanks for the ideas...Is NAPTHA the same thing as COLEMAN stove gas? Can I use a hard plastic card to scrap with or will that scratch the alum? What do People use To clean there Aluminum??
Brock
Postby Rigsby » Mon Nov 08, 2010 6:00 pm
Ive use aerosol brake cleaner before, it is basicly alchohol. and easily softens the adhesive
steve
DOOIN IT THE YAARKSHA WAY--FA NOWT, THA NUS !!
Rigsby
Postby NathanL » Mon Nov 08, 2010 7:19 pm
Heat gun/hairdryer or if you want to go the chemical route oven cleaner will work.
NathanL
Brock wrote:thanks for the ideas...Is NAPTHA the same thing as COLEMAN stove gas? Can I use a hard plastic card to scrap with or will that scratch the alum? What do People use To clean there Aluminum??
Naptha is lighter fluid.
NathanL
Postby S. Heisley » Mon Nov 08, 2010 9:16 pm
:o In that case, I wouldn't use the heat gun or hair dryer in combination with the Naptha!!!! :cigar: (...Not that you would.) :lol:
Postby starleen2 » Mon Nov 08, 2010 9:18 pm
yes - basically - see the coleman MSDS sheet for all the details
Light Hydrotreated Petroleum Distillate (Naphtha)
http://zenstoves.net/MSDS/Coleman.htm
starleen2
5th Teardrop Club
Postby bobhenry » Tue Nov 09, 2010 12:35 am
The pvc cleaner for glueing the plumbing maybe ? We know it softens the pvc pipe.
MEK Methyl Ethyl ketone (the main ingredient in paint stripper) ?
Acetone (the main ingredient in finger nail polish remover) ?
Just a few thoughts. Report back and let us know what finally worked :thumbsup:
Postby doug hodder » Tue Nov 09, 2010 10:01 am
I think you'll find that oven cleaner will etch/discolor the finish on the aluminum, they're pretty caustic. It might get off the plastic, but I'd plan on painting it afterwards. Doug
Postby aggie79 » Tue Nov 09, 2010 1:52 pm
I have the same issue but perhaps not quite as bad as your situation. Denatured alcohol has worked pretty well for me. I'm also using the "non-abrasive" (white) Scotch pads if the alcohol alone doesn't work. If you go this route, I'd test it on some scrap aluminum or in an inconspicuous area to make sure it doesn't scratch your aluminum. (The aluminum I'm using is anodized and that is probably what prevents the scratching with the pad.)
Postby dh » Sat Nov 13, 2010 1:50 am
Lacquer thinner? Perhaps B-12 Chemtool? Test on scrap first.
dh
Postby DMcCam » Sat Nov 13, 2010 2:24 pm
You might try rubber cement thinner too. It dissolves just about any adhesive and doesn't seem to effect any surface I've used it on.
DMcCam
