by Marck » Fri Jul 08, 2005 1:35 pm
I had a similiar problem when I was doing the drop floor in the SixPack.
I had one tape measure in the tear and one at the table saw, I measured in the tear, then went to the saw, and did the cut, got in the tear with it and found it was almost 1/4" short. I was not happy.... later I compared the 2 tapes, measuring the same board with both, yep, about 1/4" off, seems the tab on the end of the one tape was not on right or something making that difference...I now use the same one for all cuts, & measurements.
You want to build WHAT?????
40 isn't middle aged....
IT'S YOUTH PART II
