Since you are like so many paranoid folk without a city & state on your avatar I went to your website to find out where you were.
In Conneticut huh ! If you are a cold, or even cool , weather camper spring for the foil backed polyisocianurate it is the best R value for the thickness. The white styrofoam board shrinks do not encapsulate it in a wall where there is no access. The pink and blue are good and exactly the same except for color (Dow vs Owen corning). The Dow blue is what I used but the foil face adds a full 1 point to the r value and although a bit more expensive you only buy it once so why not?
We just went thru a thread about r values . Here is a bit of info I was able to unearth......
Panel #1 is a stick built panel w/3/4" Styrofoam insulation consisting of;
2 sheets of 1/4" plywood .31 ea .62 R
32sq foot of 3/4 Styrofoam 20.4 sq ft 3.75 x .64 = 2.4
7. 8' 1X3's 11.6 sq ft .93 x .36 = .3348
so your composit 1x3 and foam wall is 2.735
Wall #1 total "r" value is 3.355
A bottle of glue n/a ?
a hand full of nails and a quart of paint (inside finish)
You can add 1.056 to this wall by substituting 3/4 foil faced polyisocyanurate ( 5.4 "R" value) in lieu of the blue (or pink) foam
Panel #2 is a solid sheet of 1/2" plywood with a foam backed rug glued to one side consisting of;
1 sheet of 1/2" plywood .63
32 sq foot of foam backed rug 1.23 (see note)
wall #2 total "r" value is 1.86
1 quart of rug glue n/a
curiously a material backed carpet is 2.08 instead of the rubber backed 1.23 ndicating the foam rubber is a better thermal conductor of heat and cold.
here is some more info.....
http://www.homeconstructionimprovement.com/foam-board-insulation-values/
