The Trailer Frame
The Trailer Frame
Postby xe1ufo » Fri Jul 08, 2005 6:08 pm
Here in Mexico they sell a square tubing used for a lot of smaller industrial structures. They call it PTR. With 470 factories in our town, I can buy it by the kilogram at the junk dealers. Is this stuff any good as the basic bottom trailer frame and tongue? For the lighter weight 4 by 8, what size is good, if any?
I am thinking of a frame that will withstand our bad roads and also the many non-paved roads we frequently travel.
Thanks in advance!
Dr. Steve
Central old Mexico
xe1ufo
Postby Chris C » Fri Jul 08, 2005 6:14 pm
There are differeing opinions on that subject, but in my opinion, 2" x 2" x 1/8"wall is a suitable tubing for a tear. Some will say that is overkill, but if the roads are a poor as I imagine you will be using, I think you'll need it.
Chris :D
Chris C
Postby xe1ufo » Fri Jul 08, 2005 6:36 pm
Hey Chris:
Thanks! Oh, and I have much gratitude for Norman, Oklahoma. My missionary parents met there in 1954 ...
Dr. Steve
Central old Mexico
xe1ufo
Postby Chris C » Fri Jul 08, 2005 6:47 pm
Nice little college town. I moved here 6 1/2 years ago after living just North of here in Oklahoma City all my life except while in the Military. Like this little town. I live out in the country on 6 acres and would never move back to town. In fact, I'd love to live somewhere where the nearest town didn't even have a stop light! :lol:
Chris :D
Chris C
Postby cracker39 » Wed Jul 13, 2005 1:28 pm
My NT utility 4x8 utility trailer is constructed of 1 1/2"x3"x3/32" "U" channel and is rated for 1180 lbs GVW. Since my Squidget shouldn't weigh more than 1400 lbs loaded, I think 2"x2"x1/8" should be plenty strong enough. I'm using 3"x3" x 3/16" for the single piece tongue with two 2"x2"x1/8" side braces to help support it.
Dale
Dale
cracker39
Images: 233
Postby angib » Wed Jul 13, 2005 2:35 pm
Dale wrote:My NT utility 4x8 utility trailer is constructed of 1 1/2"x3"x3/32" "U" channel and is rated for 1180 lbs GVW.
Dale, thanks for those measurements - I've added them to my tongue strength page so I hope they're accurate.
Incidentally, as your 3" x 3" x 3/16" tongue is off the scale, I've run the spreadsheet on it which gives a section modulus of 1.73 in3 - or 3.4 times stronger than a single 2" x 2" x 1/8" tube.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby cracker39 » Wed Jul 13, 2005 4:40 pm
Andrew,
You are obviously quite an engineer, being able to make those stress measurements. By "off the scale," do you mean that the 3x3 is overkill? My one tongue piece will be approximately 4 1/2 ft, coming from the center of the frame, with two braces, one from each corner, joining the center piece about 3 ft from the frame. All 3 pieces will be welded to the front two cross members, but going only 10 inches from the front to the back of the 2nd cross member. You can see this new frame design at http://web.tampabay.rr.com/wdsummers/squidget2.html. I'm not sure if I should cut the center piece down from 3x3 to 2x2. What do you think?
Thanks,
Dale
Dale
cracker39
Images: 233
Small towns
Postby Guy » Wed Jul 13, 2005 5:41 pm
I am from New York and lived in SoCal for the last 18 except for two years spent in Arrowtown, New Zealand in a ski resort. You had to drive 2 hhours to hit a stop sign and a little further on down the road in Invercagrill ,at the southern tip of New Zealand, you hit you first traffic light.
Regards,
Guy
Guy
Images: 44
Postby angib » Wed Jul 13, 2005 7:02 pm
Dale, I can't get this description:
to match your diagram:
Where's the "one tongue piece"?
By off the scale for your 3x3x3/16, I just meant bigger than any of the sizes I had listed. Our host, Mike, likes to recommend the twin 2x2x3/16 tubes (ie, an A-frame) that he has on his chassis and your single 3x3 is only some 30% stronger.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby cracker39 » Wed Jul 13, 2005 7:33 pm
Andrew,
As a former tech writer, I understand how easy for what you see in your mind to look correct on paper to yourself and be muddled to others. I’ll try to clarify. In the top view diagram, to the right, the main tongue piece is labeled C (3”x3”). The connecting 2”x2” braces are labled A, one from each corner to the tongue. They are welded to the tongue about 3 feet from the front cross member. These 3 pieces are the rightmost pieces in the diagram. As you can see, the front two cross members are separated by only 6 inches. This gives me only 10 inches of the rear of the tongue that can be welded to the two cross members due to the drop-down floor not allowing it to be welded any farther back, same with the corner braces. That is the weakest part of this setup. I may need some pieces of steel plate added between the center tongue piece and the two cross members for additional strength. I’ve undated the diagram again on my site, correcting the side view drawing to match the top view.
Dale
[/img]
Dale
cracker39
Images: 233
Postby xe1ufo » Wed Jul 13, 2005 8:20 pm
Dale:
Why do I get an empty box with an X in the corner for your two pictures? All we are expexting from you is perfection!\ :lol:
Dr. Steve
Central old Mexico
xe1ufo
Postby cracker39 » Wed Jul 13, 2005 9:06 pm
Dr. Steve, I don't know what you are seeing..or rather not seeing. Do you have the html disabled? I am seeing the diagram of my chassis in both posts from Andrew and myself above. It is linked to a jpeg image on my web site host via an html statement in our posts.
Dale
Dale
cracker39
Images: 233
Postby xe1ufo » Wed Jul 13, 2005 9:12 pm
I am not having trouble seeing anybody else'spictures. And yes, I have Hot Tamale enabled (This is Mexico ...) I really would like to see your wiring diagrams? May I have a link? Pretty please?
Dr. Steve
Central old Mexico
xe1ufo
Postby madjack » Wed Jul 13, 2005 9:30 pm
...xe, right click on x and select "view image"(or whatever your browser says)...you should now see pics
Postby xe1ufo » Wed Jul 13, 2005 9:43 pm
madjack:
It still doesn't work. I will shut down and restart. Maybe try with the FireFox browser.
Thanks! What town in Lousianna are you in? We used to visit Homa, and Sulpher a lot.
Dr. Steve
Central old Mexico
xe1ufo
