angib wrote:I'll throw in my heretical view: any solvent in epoxy is a bad idea if it is for protecting good wood. Your aim should be to create an epoxy-rich layer that will be as nearly waterproof as possible. If there is a solvent in it, it will leave voids when it evaporates, creating a less waterproof layer, offering less protection to the wood.
If the use of the epoxy is to reinforce rotted or softened wood, which I understand was the purpose of CPES, then solvents may be a good idea - I've no experience of that so I don't have an opinion.
Epoxy is not paint, and however much anyone reveres their grandfather's instruction to get a coating to soak a long way into wood, the mechanics are different. Soaking epoxy into end-grain, for example, is primarily a one-shot deal - you must continually feed the same mix of epoxy into the end grain until it stops being absorbed. Typically, this means applying epoxy to the end grain maybe six times in ten minutes and only stopping when the epoxy starts to harden.
Hello. I'm Steve Smith. I'm the guy who invented Clear Penetrating Epoxy Sealer [also known as CPES], back in 1972. I've gathered up and organized quite a bit of information about it, since then.
I originally invented it as a solution to slightly deteriorated wood. It turned out it also was (I modestly assert) the World's Greatest Primer for paint or varnish on wood.
It is distributed by Smith & Co. under two names, CPES (above) and MultiWoodPrime. The MultiWoodPrime website http://www.multiwoodprime.com/ has information about its benefits on new or sound wood. There is information at the main company website http://www.smithandcompany.org/ about the product and its use in the restoration of wood. One of my distributors is The Rot Doctor, who serves the general public with Internet sales.
The underlying science of how it works is given at http://www.woodrestoration.com/. There you can see time-lapse photographs,pictures thru microscopes, mechanical tests and even an open standard for this kind of product.
The information at those websites should answer a lot of your questions. If it makes new ones, just ask.
Steve Smith
...the rot was in the uncoated portions on the inside of the galley...when I removed the rotted wood, I found a solid 1/8" area on both the sides and edges that was totally unaffected by the rot...this was with just the "regular" epoxy...
