Hi everyone,
I just started building a Kuffel Creek Cubby.
I would like to have the sides be woodgrain finish when I am all done. I don't know if that means using fiberglass or spar varnish or what, but my question is: How do I follow the plans without tons of screw heads showing on the finished outside?
Keep in mind I would also like to keep this as simple as possible. Does this mean I have to countersink all screw heads and fill in with plugs? Is there some simpler way?
Do I only use screws around the edges, where they will get covered with trim anyways?
Any comments greatly appreciatted,
-Ben
