bending plywood
bending plywood
Postby Clipper » Thu Dec 30, 2010 11:28 am
Will 1/4" hardwood plywood easily bend around 17" & 19" radius curves?
Clipper
Re: bending plywood
Postby Steve_Cox » Thu Dec 30, 2010 11:40 am
Clipper wrote:Will 1/4" hardwood plywood easily bend around 17" & 19" radius curves?
Easy for some folks, more difficult for others. 8)
But will 1/4" plywood bend around a 17" and 19" radii? Yes.
Most use nylon straps to torture the plywood into conformance.
Steve_Cox
Images: 196
Postby Clipper » Thu Dec 30, 2010 11:47 am
On the interior 17" is it easier to bend one piece throught the entire curve or bend two edges and meet in the middle.
Clipper
Postby aggie79 » Thu Dec 30, 2010 12:58 pm
You may want to try "pre-bending" the plywood before installing. This is a picture from Donutboy's gallery showing staps used to curve the plywood prior to installation:
Postby kennyrayandersen » Fri Dec 31, 2010 2:02 am
aggie79 wrote:You may want to try "pre-bending" the plywood before installing. This is a picture from Donutboy's gallery showing staps used to curve the plywood prior to installation:
Good idea! I like that one
kennyrayandersen
Images: 38
Postby Clipper » Tue Jan 04, 2011 9:30 pm
Found the closest Lowes has flexi ply, pricey but worth it, no hassle and the project will be done with better results.
Clipper
Postby starleen2 » Tue Jan 04, 2011 9:52 pm
Clipper wrote:On the interior 17" is it easier to bend one piece throught the entire curve or bend two edges and meet in the middle.
I'll tell you from Experience - It's a lot easier to do with one piece than trying to do it in two - The seam might not close up very well
starleen2
5th Teardrop Club
Postby Gage » Tue Jan 04, 2011 10:15 pm
I only use 1/8" birch and don't worry about it bot bending. 1/8" is plenty strong unless your building a flat sidded and top (no curved section, non-traditional), teardrop. :thinking:
Image Image Image
Gage
Images: 28
Postby boomboomtulum » Wed Jan 05, 2011 12:52 am
I'll second what Gage said, 1/8 BB will make a tight bend. You double it up and get 1/4 with alot less trouble and dont worry about it exploding. Not sure if you have 1/4 bendy ply available in your area but it will make a tight radius but is $$. We have it at the local hardwood stores in Sacramento
http://www.mikenchell.com/forums/album_ ... c_id=37109
Have'nt been everywhere yet, but it's on my list.
boomboomtulum
Images: 50
