Page 1 of 1
Cutting foam panels
PostPosted: Mon Jan 17, 2011 12:08 pm
by cuyeda
I came across this simple tip for cutting foam panels. Just making our job building trailers easier.
Click here to view video from Fine Home Building
PostPosted: Mon Jan 17, 2011 1:30 pm
by angib
That's ace! It's always nice to see the lateral way of doing something that really works - I want to try this.
My equivalent is to use an electric (meat) carving knife to cut upholstery foam. Other tools really struggle but in foam this really is the hot knife through butter.
PostPosted: Mon Jan 17, 2011 2:18 pm
by Dusty82
That really is genius! I'll certainly give it a try when it comes time.
And I'll second Andrew's suggestion to use an electric carving knife for cutting polyurethane or latex foam for upholstery. They can be found in the kitchen appliance section at Wally World for about $18, and they really do work like a hot knife through butter. A lot of beginning upholsterers use them for this purpose because they're a LOT cheaper than a foam saw ($175 and up.)
PostPosted: Mon Jan 17, 2011 4:03 pm
by H-Balm
Well, I know what I am doing later today!
PostPosted: Fri Jan 28, 2011 11:04 am
by steve smoot
now you tell me... :cry:
PostPosted: Fri Jan 28, 2011 10:16 pm
by starleen2
Neat - today I used my table saw to cut some blue foam insulation board - worked pretty well. I needed some 1 inch thick pieces, but the hardware store was out of 1 inch - so I went with two layers of 1/2 inch - which meant that I had to make each cut twice. The table saw worked as expected with little foam dust being generated. :twisted:
PostPosted: Sat Jan 29, 2011 8:07 am
by kirkman
So does this mean I have to build another tear just to try this out? ......Well OK if I have too. :lol:
PostPosted: Sun Jan 30, 2011 9:34 am
by sdakotadoug
Makes me want to run out and buy some form. Great tip, Thanks Doug
PostPosted: Sun Jan 30, 2011 2:12 pm
by Classic Finn
Dat B Da Ticket. Got a few of them around here so off to sharpen the edges. Will come handy shortly. :thumbsup:
Thanks for posting that Cliff :thumbsup: :applause:
