paint ?
paint ?
Postby 3822sean » Tue Jan 18, 2011 9:02 pm
:thinking: got my floor done getting ready to start my walls has anybody used exterior house paint to paint the outside ,,,,,,,,,,,pros and cons, any opinions there are just so many options thanks
3822sean
Images: 37
Postby b.bodemer » Wed Jan 19, 2011 10:03 am
I used paint for my trim..........no problems but it is garage kept.
Barb
b.bodemer
Images: 328
Postby bobhenry » Wed Jan 19, 2011 10:31 am
Both of mine set out 24-7 in the weather and I have both now painted with oil base tractor enamel from the farm supply store. This stuff is bullet proof in my opinion. Rolled on 2 heavy coats on bare wood. The barn has been thru 2 winters in the snow and ice and looks as good as the week I painted it.
paint
Postby 3822sean » Wed Jan 19, 2011 11:25 am
thanks for the repl :thumbsup: ies
3822sean
Images: 37
Postby H-Balm » Wed Jan 19, 2011 5:53 pm
tractor paint.
Sounds pretty cool... a good conversation point, at least!
H-Balm
Re: paint ?
Postby caseydog » Wed Jan 19, 2011 6:08 pm
3822sean wrote::thinking: got my floor done getting ready to start my walls has anybody used exterior house paint to paint the outside ,,,,,,,,,,,pros and cons, any opinions there are just so many options thanks
I used exterior house paint, and it is working fine. Mine is also stored indoors but has been camping many times. On two occasions, I drove at highway speeds for four hours in heavy rain.
I put a new coat on in the spring, just to spruce it up.
CD
My build journal is HERE
caseydog
Images: 515
Postby LMarsh » Fri Jan 21, 2011 10:52 am
I used exterior latex with a good primer over an aluminum skin. We've driven through everything except ice and snow. Its stored in a 3 sided garage all winter and still looks great. It does have a few nicks where the aluminum is showing through but its easy to wash, touch up, and the paint was inexpensive compared to other specialty enamels.
LMarsh
Images: 187
Postby sdakotadoug » Sun Jan 23, 2011 9:10 am
I would consider enamel deck and porch paint. I frequent several boat building sites and the above is recommended for things that may be partially submerged for a couple of weeks at a time. Lots of these boats are stored outside also. Doug
sdakotadoug
Postby zapj » Sun Jan 23, 2011 7:34 pm
I used Lowes exterior high gloss latex enamel over a primer and have had no problems. The camper is kept indoors when not in use. I carry a small container of the paint when I travel just in case the finish gets nicked. Since it is latex I don't need a thinner for brush clean up. On a 3200 mile trip last July I had no nicks or chipping of the paint from road debris or weather.
jim
zapj
Images: 40
paint
Postby 3822sean » Sun Jan 23, 2011 7:49 pm
:) sounds good to me ,,thanks everybody for all the help
3822sean
Images: 37
Postby ashkanr » Fri Feb 25, 2011 2:11 am
Great question...great answers!
Thanks, I just got the answer to my question :D
Ashkan
Link to: My Album
ashkanr
Postby Rlowell » Sat Feb 26, 2011 12:38 am
My two cents.
Just completing my first build. I used the thinned polyurethane (3 coats) to seal the ply, two coats of oil base primer, and three coats of valspar exterior oil base paint (Gloss). I get impatient with the drying time but it looks great and should last a while. Do I really need it to last for thirty years?
Photo in album.
Thanks and good luck.
Rod
Plan your work...work your plan...at least that's the plan. Oh, just do it anyway!
gallery/image_page.php?album_id=1425&image_id=76342
Rlowell
Images: 42
Postby Sam I am » Sat Feb 26, 2011 10:24 pm
I used Sears porch and floor latex paint. Two coats brushed on over a white latex primer. I built it in 2006, and it has held up perfectly. The tear is kept in my garage except when being used.
Sam I am
Images: 106
Postby cracker39 » Thu Mar 10, 2011 10:49 am
I used Glidden latex porch and deck enamel on the original Squidget, over a Zinser primer, over an epoxy resin sealer. Five years use and the paint is holding up well according to the current owner who contacted me a few months ago. Latex will stretch and contract with temperature changes, whereas oil based will tend to crack and peel after a few years.
I am starting to apply the resin to the PT's skin, and plan to use the same primer and paint on it. I've read that the glossier the paint, the more it will show imperfections, but I used the high gloss enamel with good results. Proper preparation of the skin is the key to a good looking finish. I spent hours filling and sanding with Bondo first for the larger spots (seams, screw holes, tiny cracks in the plywood) and finally with water putty to get it really smooth.
UPDATE: I went to buy paint at Home Depot and found out that latex porch and deck enamel no longer comes in gloss. I bought some Behr latex P&D a while back and it was low-luster. I bought Glidden this week and it is satin finish.
Dale
cracker39
Images: 233
