Cutting the doors
Cutting the doors
Postby KenC » Wed Feb 02, 2011 1:59 pm
Hi All,
I'm about ready to cut my doors out and wonder if anyone has used this zip bit attached to the router with good results or shoud I stick with a jigsaw.
I'll cut my outside door panels first from my outside wall, then glue up my inside walls then cut those door panels out and build the doors
KenC
Images: 41
Postby aggie79 » Wed Feb 02, 2011 4:26 pm
I can't say anything about the zip bit but I cut my doors with a 1/4" spiral carbide bit and router with template and bushing.
In the picture, I didn't cut full thickness at the red marks. I left the door "connected" so I could skin the inside of the wall and to keep from having to worry about the door warping.
A 1/4" gap is too much, but after I lined the door and jamb with 1/16" thick aluminum molding, it came out about right.
Postby LDK » Wed Feb 02, 2011 10:18 pm
Since my door is square, I cut my door out on the waste side with a jig saw and then used a straight edge and a router with a flush trim bit and took out the rest of the material necessary for the trim etc. It turned out really well. ---- I marked my door dimensions on the plywood (26"x36") and then marked another set of dimensions 1/4" away from the 1st one. I then cut it out in the waste between the lines and then used a straight edge and a router with a flush trim bit on both the door and the wall edges to take out the rest of the material for the trim. I thought I should explain this post alittle better. :)
LDK
Postby jss06 » Thu Feb 03, 2011 8:21 am
I used a skill saw to plunge cut the straight edges of the door then used a jig saw to cut the radius corners.
jss06
Palladium Donating Member
Postby KenC » Fri Feb 04, 2011 7:56 pm
Hi,
Thanks for everyones input, I went with the jigsaw and cleaned up the edges with a router. I was afraid the zip bit would leave to much of a gap between the door edge and the wall.
KenC
Images: 41
Postby dan galvin » Sat Feb 05, 2011 9:01 am
good choice zip tool is hard to control :thumbsup:
dan galvin
Images: 43
Postby KenC » Tue Feb 08, 2011 11:56 pm
Here is a pic of the door after cutting it out with a jigsaw and cleaning the edges up with a router, the forum is great, thanks again for all the help and advice. :applause:
KenC
Images: 41
