Page 1 of 1
Question that I need an Idea on.
PostPosted: Sat Feb 05, 2011 8:54 am
by Classic Finn
I have a question for you folks. Along with the kit came a roof rack which to us here looks like a VW Beetle model. Even so its unique and was wondering if any of you have ideas as to how I can widen the leg area to be able to set it up on the ceiling better and more securely.
It just doesnt sit correctly. I was thinking it could be widened? to hookup onto the edge moulding??
Should I take it to a shop where the legs can be extended via bending and adding plates to it or?
Here is a pic of it
PostPosted: Sat Feb 05, 2011 9:28 am
by GPW
CF ... Is it mounted to a crossmember (s) ??? That should be secure eh ? A shop will make it right ... could be "involved" (pricy) ... :o
I think it looks Fine !!! :thumbsup:
PostPosted: Sat Feb 05, 2011 9:33 am
by toypusher
Heikki,
Personally, I do not like the look as it is right now. If I was doing a roof rack, I would want it to be much lower to the roof of the tear and have it present a much lower profile. And yes, I do think that it at a minimum needs to be move more to the front of the tear to sit in a 'balanced' position.
PostPosted: Sat Feb 05, 2011 11:06 am
by 48Rob
Heikki,
My opinion...
Cut it up and rebuild it to fit, or use it for ideas and build one that looks like it belongs.
The legs should be vertical, or near vertical.
Splayed out, it will look like you tried to stretch a rack that was too small.
There should only be 2-4" of clearance from the top of the tear, to the bottom of the rack.
The curve of the rack frame should match the roof.
And finally, when finished, you should be able to put at least a couple hundred pounds on it without fear of damage to the rack or the roof.
Rob
PostPosted: Sat Feb 05, 2011 11:30 am
by Miriam C.
:thinking: Start over! You are right, that doesn't look right. ;)
PostPosted: Sat Feb 05, 2011 12:41 pm
by bdosborn
Cut the legs off, attach it to Grants roof rack and position to taste.
http://www.lilbear.teardrops.net/parts5.html#RoofRack
PostPosted: Sat Feb 05, 2011 4:13 pm
by Aaron Coffee
My thought would be to start from scratch and use it as a guideline, and find out if it is from a VW, then sell it to a VW collector.
