3822sean wrote::thinking: on a door how much bigger should the opening be bigger than the door with the standard molding ?
grant whipp wrote:If you are going to use a piano-type hinge and intend on "burying" it (mounting the "leaves" between the door and wall end), allow an extra 1/8" or so on the hinge side ... otherwise, yeah, 1/4" all around.
CHEERS!
Grant
