Below is my first frame drawing for a 5x10 Benroy style. Steel only, not including the frame is weighing in around 220lbs. Have I completely overkilled this thing? I'd like to get it lighter, but I have the following caveats.
1. I'm in Colorado so this will see some dirt and washboard roads.
2. Body construction will be 3/4 solid ply (no frame and foam)
3. I'd like to keep the angles for a tongue box.
My initial thoughts to lighten it up are any/all of the following:
a. remove the 2x2 running down the center.
b. cut the inside cross-members down to 1x2.
c. bring the 3x2 tongue back to the second crossmember instead of the third.
Of course it needs to be safe...I'm a worry wort.
I'll be using Andrews balance and tongue weight spreadsheets, but need to finalize the overall design first.
On other fronts I also have some general questions related to weights.
1. Any idea what I should estimate the weight of a 2000lb torsion axle w/brakes/wheels and tires to be? I've checked Dexter info, but it wasn't readily available.
2. In estimating plywood weight I'm using 75lbs for a 4x8 3/4 inch sheet. Am I in the ballpark?
Thanks in advance for any and all replies!
-Ben
