door sizes
door sizes
Postby bpichoff » Tue Feb 22, 2011 11:15 pm
I bet this has already been asked but I am having computer problems going from one link to another... so I couldnt find a answer we are ready to cut out doors we are thinking 30inx36in would that be a good size and should the opening be beefed up? walls are 11/32 plywood 1x3 spars with 1/4 ply inside should We use something bigger for door framing? the camper size is 5ft.x 10ft
thanks for any help
bpichoff
Postby Wolffarmer » Wed Feb 23, 2011 1:09 am
30 inch wide works good for me. I took my width from the house door I use most often. 36 inch high sounds ok also. Kind of depends on how much side wall strength you need. When I framed up my wall and door opening I put oak in for the hinges. Probably over kill and it did add weight. I cut the opening for the door before I started to frame it up. then I framed wall and door separately, leaving a bit sticking out and used a trim router bit to cut off the excess of framing material hanging out. It worked for me. For ply I used 3/8 outside and 1/8 inside with 1 inch thick spars. Sounds like your ply is thicker so your walls should be plenty strong. Mine are plenty good.
From your description it sounds like you are going to put the 1x3 in the wall and seal the wall up and then cut it out. Hoping to hit the near center of the 1x3. Works for me if I could plan that well
:lol:
Randy
Wolffarmer
Images: 309
thanks
Postby bpichoff » Wed Feb 23, 2011 1:50 am
Thank you thats how I have it marked out was just scared it would be too small we havent installed the inside yet will do that next :o
bpichoff
