hallotp wrote:From what I have researched, it would double the weight of the body, but might also require less framing.
hallotp wrote:OK, that makes sense, but what about attaching the aluminum directly to a frame..say welded steel? Do you have to have the ply beneath if you use .040 or .050? I understand the issue of oilcanning, but first airstream do it this way? or regular cargo trailers for that matter?
Thanks again!
Hal
