KenC wrote:SoCal Teardrop sells a smaller fan unit and draws less amps
GuitarPhotog wrote:Found it. Not the most user-friendly site.
Thanks for the lead - 6" will fit my needs.
<Chas>
The body frame is 1" iron angle iron welded with atrocious welds.
My speculation is that it was made by a couple of aircraft engineers who knew how to work with aluminum and how to design, but who couldn't weld worth a damn
<Chas>
Shadow Catcher wrote:Or use computer case fans. Cheap, if you use three speed fans adjustable, very low power draw.
48Rob wrote:The body frame is 1" iron angle iron welded with atrocious welds.
<Chas>
Is it safe to proceed?![]()
Rob
GuitarPhotog wrote:Shadow Catcher wrote:Or use computer case fans. Cheap, if you use three speed fans adjustable, very low power draw.
You didn't read the part about needing a pop-up vent and making it weatherproof did you
GuitarPhotog wrote:Well, the So-Cal Teardrops fan isn't going to be workable in my situation![]()
So I'm off to the computer store to look at computer fans.
How do you vary the speed of such? Just put a rheostat in series with the motor?
<Chas>
