NEED HELP: A question from my wife...
Postby John Ayers » Wed Mar 30, 2011 2:17 pm
My wife asked me a question...
... and to be honest I don't know how to answer this. I need help. :worship:
The question goes like this:
(W) - Hon. I know your talking about building the trailer as tight as a drum... and we don't want windows or a hatch on top because that just kills the R Value of the camper, plus we sleep better. But do you think that the three of us sleeping in the camper all night might die of asphyxiation?
(Me) - *In my best Antonio Banderas voice* Don't be ridicules my love... er... uh... :oops:
And then I thought about it. :thinking:
160 Cubic Feet. 3 humans converting oxygen into carbon dioxide... and suddenly I'm not sure how to explain why we don't die in our sleep. Can someone please help me with this.
John Ayers
Postby planovet » Wed Mar 30, 2011 2:22 pm
Simple. If you built it "as tight as a drum" and don't have any ventilation, then you WILL die.
As usual, the wife is right.
ImageMark (& Cindi)
planovet
The Cat Man
Postby KenC » Wed Mar 30, 2011 2:24 pm
Or you can read this sticky
Air Tight Teardrops can KILL YOU
http://tnttt.com/viewtopic.php?t=40667 ;)
KenC
Images: 41
Postby rbeemer » Wed Mar 30, 2011 2:33 pm
I think you will need a vent at the top, you can use any RV vent but most prefer something like the fantastic vent. You will not lose a lot of R value with just the vent plus the air movement will keep moisture down.
Tell the wife that the tight as a drum comment is for the sides and joints of the trailer that will prevent leaking, we will need ventilation because how else are we supposed to get the smells and sounds of the great outdoors inside. 8) :lol:
Rick
If ducks had scales, would fish quack?
rbeemer
Postby desertmoose » Wed Mar 30, 2011 3:00 pm
Hmmmmm. at my age, I'm more worried about getting the smells of the great INDOORS outside...
Sam
desertmoose
Images: 98
Postby mcspin50 » Wed Mar 30, 2011 3:03 pm
:lol: :lol: :lol: My thoughts exactly!!
Lil M.
In every walk with nature, one receives far more than he seeks. - John Muir
Generic Benroy Build Journal here - My LilScamper Update Journal here
The Lily Pad...Image My LilScamper...Image Image
mcspin50
Images: 158
Postby Miriam C. » Wed Mar 30, 2011 4:36 pm
:thumbsup: Ditto the vent! Heat rises and unless you are going to camp only in Winter you will need a vent and some other opening for circulation. I read about some campers gasping for air and decided to make it water tight and never mind the air tight. Got a big window too. 8)
Postby Aaron Coffee » Wed Mar 30, 2011 5:02 pm
As long as we are on the subject, here is a question I've had. If their is now breeze but I have the vent and at lest one window open a little bit, how does the c02 get out and the fresh air get in?
Aaron Coffee
Images: 26
Postby John Ayers » Wed Mar 30, 2011 5:15 pm
LOLZ :lol:
Yep, won't be doing that. Maybe I'll make it a convertible... :wacky
... or just get more Life Insurance... hard choice to make.
John Ayers
Postby Miriam C. » Wed Mar 30, 2011 6:20 pm
Aaron Coffee wrote:As long as we are on the subject, here is a question I've had. If their is now breeze but I have the vent and at lest one window open a little bit, how does the c02 get out and the fresh air get in?
:lol: If C°² sinks then you can expect the oxygenated air to mix with it. Warmer air will flow out the vent causing cooler, fresh air to flow in the window. We call it a draft in the house but in the TD it is circulation.. :lol: ;)
Re: NEED HELP: A question from my wife...
Postby chorizon » Wed Mar 30, 2011 7:08 pm
John Ayers wrote:(Me) - *In my best Antonio Banderas voice* Don't be ridicules :oops:
Funny, I heard Balki Bartakamous. :lol: :lol: :lol:
chorizon
Images: 94
Postby CliffinGA » Wed Mar 30, 2011 8:10 pm
John the other thing with the vents and windows is condensation, with them you have very lil and without you wake up with it raining inside :lol:, my lil tear has no vent but does have windows and between me and the wife we wake up with the walls sweating. I just tell her its because she's so hot :worship: but she never believes me :lol: .
Cliff
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby oklahomajewel » Wed Mar 30, 2011 9:41 pm
When I've slept alone... no problem , but have a crank open roof vent and always keep it just slightly cracked open.
More than once, when I had a friend sharing the camper , and forgot to crack open the vent or had a window open , I did wake up in the middle of the night with a faint feeling ... dizziness. I had to open the vent and open the door for a minute to get some fresh air then I was fine.
GET A VENT of SOME kind.
Jewel
oklahomajewel
Images: 82
Postby wannabefree » Wed Mar 30, 2011 10:59 pm
This is a fun problem and I did the math once before, but can't find it now. So I'm going on memory this time - sometimes dangerous at my age.
Air, the stuff we breathe, is about 20% oxygen and nearly 80% nitrogen. there are some other gases in the mix, like CO2, but it's less than 1%. Nitrogen is harmless, but CO2 kills.
Now,you breathe about 1 cubic foot of air a minute and convert a portion of the oxygen to CO2. Actually, the air you breathe out is 4-5% CO2 more CO2 than you breathed in, so maybe 16% oxygen. So you can rebreathe that air maybe 5 times before the oxygen is completely depleted.
If your trailer is 160 cubic feet and there are 2 of you breathing, you get 80*5 minutes, or 400 minutes or 6 hours 40 minutes before the air is completely replaced with CO2. But you'll be dead long before then.
So crack a window open, better 2, even better a window and roof vent. The window / roof vent combo is best because you can get some convection going which gives you good air circulation even with no wind.
Sorry for the lengthy post. I'm an engineer. Nuff said.
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Postby jdarkoregon » Wed Mar 30, 2011 11:56 pm
John, your wife asked a GREAT question. The solution is simple and we are so glad we won't be reading about your in the obits.
Open a vent or two, You'll stay plenty warm and the fresh air will sure dilute the other odors that might kill you too.
You should be worried more about the condensation now
Have a great time, hug the wife and tell her thank
John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
