by Woodstramp » Sun Apr 17, 2011 9:28 am
Doug,
You're the fellow who built that cool little blue 50's looking stand up camper. My hat is off to you on that one...1 1/2" x 2"spars it will be. Thanks.
As to the luan....all that the local building joints (Lowes, HD) have is 1/4" thick, so I have to make that work. Plus I had originally wanted to skin this thing with 36" wide strip of aluminum, but the suplier told me the other day that this is no longer available. I have to skin it another way.....thinking now that I want to Rhino line the whole thing. 1/4" would be a stronger base for that. Probably will route grooves on the back side 1/4" to make it bend. We'll see.
I've decked the the 6'x10' frame I built this winter and started in on the base fo the walls. Got a homemade door jam and decent factory windows. The only thing that is scaring me is the roof transition and I want to get it right.
Never saw a roof on here like that the one in the pic. Is that one you built in the past or is that something you're doing now?
