Glenn Quarles wrote:
My first questions have to do with ordering the axle:
- I understand the Dexter #9 axle with torsion bar is good?
- Is there a preference for wheel/tire width?
- How much room between the side of the tire and the side of the trailer do I need for the fenders to mount?
- How are the fenders typically mounted...to the side of the body, to the frame or to the axle?
-I think I read something about the "starting angle" that needs to be specified when ordering the axle...can someone explain what I need?
Glenn
dh wrote:Welcome to the board Glen. The first thing I actually purchased for the TD was a set of rims from the junk yard, make sure to get a bolt pattern and center hole that works with the hubs you want. Next, I got some tires for the rims. Any size will work, really its just a matter of the look you are going for. I do like to stay away from odd ball sizes though as trying to find a replacement tire on the road could be a PIA. Now, with tires mounted on rims, you can determine your measurements for your axle. (You do know your trailer width, wall thickness, wall attachment method, etc. right?) If your walls will cover your frame, add your wall thickness (W) multiplied by 2, the distance from the hub seat on the rim to the back sidewall (R) multiplied by 2, your frame width (F), and your desired clearance from tire side wall to trailer wall (C) multiplied by 2, and get your hub face to hub face measurement (H). Or,
2W+2R+2C+F = H
F = bracket spacing
(H-F)/2 = stick out
Now, the fun part, you get to pick a start angle and mounting bracket. These, in conjunction with your tires/rims will determine your ride height. You have three mounting bracket options with the #9, a low profile, high profile, and 3" high profile (which may or may not be listed on the web, but is available). Pick a combo of bracket height and start angle that will give you the height you are looking for, your sales rep will be able to help you with this, and I believe Dexter has a chart for this on the #9 on line spec sheet.
Now just one more decision. Do you want brakes? I'm not advocating either way, but if you want them get them now, it's less than $100 to get them installed at the factory.
dh wrote:Glen, Sorry for the late reply. The #9 axle requires 3" of vertical movement. I have the same isue as aggie, just less dramatic as I have a downward start angle, so I'll just have to trim a hair off the wall. Also, Dexter can de-rate the axle for you, the closer you are to maxing out the load rating of the rubber the better it rides.
