UK-Brian wrote:can someome please explain the difference between epoxy resin and fiberglass resin? I have read that epoxy makes the wood very hard and water resistant, does fiberglass resin do the same thing?
thanks, Brian
Brian,
I have been building wooden Kayaks and canoes for 25 years. In that time I have only used epoxy. Virtually EVERY boat builder uses epoxy. The use of "Fiberglass Resin" which is Polyester resin, is frowned on for boat building.
There are a couple of reasons it's not the
best choice. The first is it does not adhere to wood very well, and the other main one is it's not as water proof as epoxy.
I helped a guy quickly build a strip canoe for racing. He wanted it done for some upcoming races and couldn't wait for an epoxy shipment so he went to the Big Box and bought the cheap Polyester resin. He had the the boat glassed and varnished (for UV protection) fairly quickly.
A year passed and he stopped by to ask me what was happening. The glass was delaminating from the cedar strips and there were several dark spots where water had penetrated the surface that showed no physical damage.
We pulled on one of the delaminating spots and it came free easily.
To make a long story short, 45 minutes later, all the fiberglass cloth was pulled off the hull. It came off in big sheets. The polyester resin had not penetrated the surface at all. Pulling the glass off didn't damage the soft cedar indicating it was just lying on the surface.
Others will say it works great, but the in my mind
Epoxy is superior in every way except cost. If your spending a couple thousand dollars to build a TD, what' s $100 extra to have superior protection. Water infiltration is the number 1 issue with a TD trailers longevity. Why not use the proven best product available, and I don't mean the diluted so called "penetrating epoxy"
(Snake Oil) that is so popular on this forum. I am referring to quality Epoxies such as Raka, Wests, System 3, etc.
My $.02
Larry C
