another coating ???
another coating ???
Postby UK-Brian » Mon Apr 25, 2011 9:48 pm
ok, here's something else I thought of. was in my local lumber/hardwood store I stumbled across an epoxy that is used on garage floors. has anyone used this or is it even a possiblity? I'm wanting to start my walls but still figuring out the epoxy. may break down and buy the raka brand this week. but was looking for something to use for a base coat for the floor under the black goo. can a person use the fiberglass resin or the floor epoxy with cloth to make plywood joints?
thanks, Brian
In the coal fields of Kentucky and I bleed WILDCAT BLUE!!!!!!!!!!!!!!!!
GO CATS!!
UK-Brian
Images: 22
Postby starleen2 » Mon Apr 25, 2011 10:06 pm
Do yourself a favor and order from RAKA - you'll be glad that you did. Sometimes certain products don't mix together too well. Just use the black goo by itself on the underneath - it really doesn't need a base coat
starleen2
5th Teardrop Club
