looking for wide weather stripping
Postby randy chesnutt » Thu Jul 28, 2005 3:51 pm
well i made it back from my motorhome trip. time to finish up titan. i,m looking for good weather stripping 2 inch wide x 1 1/4 inch thick. i need it for my rear hatch. been looking ,not much luck. maybe yall can help. thank you
randy chesnutt
Images: 65
Postby ceebe » Thu Jul 28, 2005 6:54 pm
I'd look for truck topper weatherstripping. I used some rather large stuff when i had a truck and it had a topper. :)
ceebe
Postby surveytech » Thu Jul 28, 2005 8:12 pm
i saw some truck topper weatherstriping at either Lowes or Home Depot.
It was probably 2 inches wide but not as thick as you need.
Maybe layers would work?
surveytech
Images: 6
Postby toypusher » Thu Jul 28, 2005 8:16 pm
Randy,
Have you thought of using some kind of rubber or plastic hose. Use the right diameter and with the compression, it should work as good as any other seal.
Kerry
toypusher
Images: 324
