Are all piano hinges made equal?
Postby DiabloCanyon » Wed May 25, 2011 10:32 pm
I realize that you get what you pay for but I was looking at the piano hinges sold at HD and then some sold at Rocklers (for a lot more) and they look comparable. Perhaps the material is more solid with Rocklers but any thoughts or recommendations on which brand/supplier of piano hinge to go with for the door?
Many thanks,
DiabloCanyon
piano
Postby 3822sean » Wed May 25, 2011 10:37 pm
dont know the different brands but as long as it is stainless you should be go to go
3822sean
Images: 37
Postby Kevin & Sandy » Thu May 26, 2011 6:13 am
Have you tried McMaster's ? They have a wide variety.
http://www.mcmaster.com/#piano-hinges/=cgymhn
Kevin & Sandy
Images: 46
Postby Steve_Cox » Thu May 26, 2011 6:39 am
Kevin & Sandy wrote:Have you tried McMaster's ? They have a wide variety.
+1
From the hazardous location continuous plastic hinge to aluminum and stainless piano hinges, I've been happy with all the piano hinges I've purchased from McMaster.
Steve_Cox
Images: 196
Postby Artificer » Fri May 27, 2011 8:42 am
+2 on the McMaster Carr hinges. Thats where I order mine from, along with a lot of other materials for work and home.
McMaster will charge a bit of a premium because they have a wide selection, and its in stock. Tools, nuts/bolts, steel... I can get it cheaper locally. If its not available, however, McMaster Carr is my first place to look.
"You get what you pay for" really is true with the piano hinges. Thin, cheaply plated hinges at the local box store are decent quality, but they're made of thin metal, and the plating will not stand up to the weather. As others have said... go with stainless. If you look at the Rockler stainless hinge, its 1-1/16" wide. Is that the wing, or total open width? If its the open width, McMaster has it beat on price, and they'll tell you specs on the hinge. Want thicker? They have it. They'll also have SS flat head wood screws to install them with. (like item 90294A201)
Michael
Artificer
Images: 16
Postby b.bodemer » Fri May 27, 2011 10:35 am
I found stainless steel piano hinges at Lowes. THey worked nicely for my td doors and on my front awning/shutter.
Barb
b.bodemer
Images: 328
Postby LDK » Fri May 27, 2011 8:08 pm
I went with an aluminum offset piano hinge from Grant at little bear tag alongs. Image
LDK
Postby CARS » Mon May 30, 2011 11:54 am
LDK wrote:I went with an aluminum offset piano hinge from Grant at little bear tag alongs. Image
What is the purpose of the off-set hinge?
Or maybe the better question is what dictates the need for an off-set hinge??
Chris'
Autobody
Restoration
Service
CARS
Postby LDK » Mon May 30, 2011 8:43 pm
With this particular hinge the screws are on the inside and the offset gives you room for a seal around the door. :)
LDK
Postby CARS » Mon May 30, 2011 10:05 pm
LDK wrote:With this particular hinge the screws are on the inside and the offset gives you room for a seal around the door. :)
OK, I understand the hinge end of the door seal. But what do you do with the other 3 sides?? Use a wider T moulding??
Chris'
Autobody
Restoration
Service
CARS
Postby LDK » Mon May 30, 2011 10:12 pm
With that hinge the offset is for the door. The seals go on the inside of the t-molding. In other words the door is out from the sides just alittle. The offset is only about 1/8", just enough room for a seal of some kind. :)
LDK
Postby CARS » Mon May 30, 2011 10:29 pm
Thanks Larry.
I guess that I didn't think that the door needed to be out.
Kinda makes sense now :applause:
Chris'
Autobody
Restoration
Service
CARS
