Want to use a HF trailer but also want a wider foundation. Can I build the foundation to overhang the base by 6 to 12 inches on each side and perhaps the rear also?
Thanking you in adance
Randy
I am currently building my trailer to extend 6" on either side and more off the back. Others have done so here also.fireicera wrote:Want to use a HF trailer but also want a wider foundation. Can I build the foundation to overhang the base by 6 to 12 inches on each side and perhaps the rear also?
Randy
Yes in my case I extended back 7" and built the floor out over the tongue of the trailer an additional 17", so hopefully the weight distribution will work out OK. In my case I have no galley off the back where a lot of weight comes into play. Fingers crossed.madjack wrote:...extending the width 6" per side is no real problem, extending the length can be a SERIOUS problem if you don't take in consideration loading/balance...even at 8' long, a TD built in a standard fashion can have serious balance problems if the axle has not been relocated back a bit...extending the length to the rear can only make this problem worse......................
Teardrop4me wrote:Do you have more info and pictures on your extention and progress? I am looking at doing the same thing.
