Here's a pic of the wasted trim:
Hope to get the hatch mostly done today.
Kerry
IraRat wrote:Kerry, how come you didn't sand down the door instead?
gman wrote:TP, my guess is that your saw had a slight angle to the blade, your second cut with a small bevel to the edge because of the thickness of the top cut was enough to make it smaller once it was trimmed out.
toypusher wrote:I'm not sure I would add anything else to the door openings. Trim the door openings first, then prop the door blank up to the opening and scribe a line 1/4" smaller than the opening. Don't think you can go wrong with that.
Kerry
