PSBreen wrote:Sorry for the delay in getting back to this thread. I think I'm going to be in the same boat as Terry. I'm planning to use framed walls with either 1/8" or 1/4" outside skins, so the walls will only be 1" to 1 1/8" thick. I was considering using a kreg jig to drill my wall mounting holes, so sitting the walls on top of the floor looks like a better way to go for me. I had thought about letting the outside wall hang over the frame, but have some concerns. While it would look better, in this case it could also cause problems. That lower section would only be attached to the frame with glue. One big fear is that any flex in the wall to floor joint may cause the lower portion of the outer wall to separate from the framework of the wall. Those skins give the wall a lot of it's strength. Just my thoughts.
My side walls are 1-1/4" thick (1/4" Plywood, 3/4" thick framing, 1/4" plywood).
The outer 1/4" plywood skin covers the steel frame.
I epoxied & bolted 1-1/2" x 1-1/2" framing to the 1/2" plywood floor.
I placed this framing 1" from edge of the 1/2" plywood floor.
I then epoxied & screwed the 1-1/2" x 1-1/2" framing to the interior walls.
I used 3M 5200 at the bottom of the wall & the 1" floor edge.
I did not bolt screw or epoxy the 1/4" plywood to the steel frame, except for the drop floor area at the entrance door.
I used 3M 5200 to attach the 1/4" plywood skin to the frame at this area.
See photo shown below.
