Does any body have any weight comparisons for these sheet materials?.
For example if I make an 8x4 panel out of 6mm ply and another out of 1.2 mm aluminium will there be much difference?
Cheers, Mark.
GRUMPYBAGDER wrote:Thats great thanks, I didn't expect to see such a big difference!.
The main reasons for thinking 1.2mm was because it was not going over a ply skin, it was going to have minimal frame work and some of it may need beating into compound curves.
I can also get shed loads of it second hand, play with it, cut it, shape it, knock seven bells out of it then give it back, all for free.
So a trailer constructed in this way (would be little more than a rolling aluminium tent) could have significant weight advantages over ply frame alloy skinning method.
Is there an alloy framed and skinned trailer on the forum, or does anyone know of the exsistance of one?.
Or is there a good reason why not.
