Sure could use some window advice
Postby driftwood » Mon Aug 08, 2011 10:25 pm
Bought a homemade wooden tear with square van windows that I want to replace, and have several questions. The rough opening is 16 3/4x16 3/4. Want to replace with a larger window (slider). Before I order, want to draw a template on the door to make sure there is room for them on my door without getting into hinge or edge of door. How do you draw the template to accommodate a "90 degree 3" radius window" as advertised by the vendors? How far does window edge typically extend beyond opening?
Thanks
driftwood
Images: 28
Postby Miriam C. » Mon Aug 08, 2011 10:53 pm
:thumbsup: You get a compass to draw the curve.
Postby doug hodder » Tue Aug 09, 2011 8:18 am
On the lip overhang, I'd call up the vendor and ask about the specific windows dimensions. Without knowing whose window it is I can't imagine anyone being of much help.
Postby PanelDeland » Wed Aug 10, 2011 1:53 pm
Call the vendor and ask for a template of the window.Make sure to ask the thickness and width of the trim so you know how much it will hang over the opening.
"I know the voices in my head aren't real,but they have some really good Ideas!"
PanelDeland
