down under tech wrote:tvlawyer: I used 1/8" ply over the spars and attached it with PL Premium construction adhesive and screws on my Cubby. After it set up, I removed the screws and filled in the holes with wood filler. Then I floated aluminum on top of that. The side trim holds it all down.
Over kill ??? "I don't think so, Tim".![]()
It will add some more weight and it will be stronger and the aluminum will not bend in on high speed maneuvers.
tvlawyer wrote:The Cubby plans show the aluminum sheet being laid over the spars. However, I feel like there should be a sheet of 1/8 ply laid over the spars and then float the aluminum over that. Using a sheet of ply should increase the overall integrity of the roof and decrease the number of dents and dings that would form between the spars. Am I over-engineering?
