by cracker39 » Mon Sep 12, 2005 3:34 pm
Besides getting all of the problems worked out and have a perfect (I hope) shape for the real sides, I have another reason for making a template. My trailer framing will be more complex than a TD, as I will have cabinetry and sheliving in both front and rear to mount, and will need identical framing pieces on both sides. When I make the template, I'll "mark" the outlines of the framing pieces on the template with 1/8" holes drilled along the edges of the framing placement so I can put pencil marks on the finished sides to draw the outlines of the framing pieces for gluing. Both sides will have the framing pieces atttached in the same exact places. I also plan to use screws with the glue to attach the framing pieces. I'll drill 1/4" holes in my template where the holes should go in from the outside of the side pieces. After making the framing outlines, I'll put the template on the outside of the side piece and use the 1/4" holes to mark the places to predrill and countersink for the screws, so I'll know that I am putting the screws into a framing piece, not empty space.
And, I'm hoping that I'll get the same results others have gotten when showing off their trailers, and have someone ask me to build them one like mine. I'll have the template all ready.
