Dealing with Sawdust
With the cold setting in here in Indiana, I'm finding moving my equipment outside more and more of a problem. I setup my sad 10 year old shop vac to start dealing with the sawdust in the garage and found the filter was clogging about as fast as I could cut. I decided to search the internet and Eureka! A Thein Cyclone was my answer.....
This is probably old hat to some of you but for the newer woodworkers, like myself. I though I would point this out. The Thein cyclone can be made at home quite easily. Basically you hook your shop vac up to it, set it on top of a bucket or trash can and it filters out the particles and major dust before it even hits the shop vac.
I used the plans from http://www.cgallery.com/jpthien/cy.htm and scaled them down for a 5 gallon bucket. The thing works WONDERS!
While I was at it I decided to pickup a new wall mounted shop vac to help give me a little more floor space. I got the Sears 5hp wall mount shop vac and got an extra extension hose. I wired a plug to a 3 way switch, one switch at my saw area and one at my workbench. I plan on putting a benchtop dust collector on a blast gate in the future and being able to turn it on from the bench would be a plus. I happened to have a 6ft vac hose that worked as well and used it for the connection from the shop vac to the Thein cyclone. I now have a wall mounted shop vac and a total of 35ft of hose from the cyclone. Loving this setup, I can collect dust in the other end of the house if I want
So if you find yourself choking on indoor sawdust I highly recommend building on of these for your work area. I'm sure it doesn't quite as well as a professional, commercially purchased dust collection system, but it helps a TON in my little workshop/garage.
