Sidewall Construction
Knowing how wood, including plywood, can 'warp' in adverse weather conditions, my questions are:
1 - Is 3/4 plywood still relatively unaffected after a few years as far as warpage is concerned?
2 - Other then time, effort and possibly cost, is a framed and skinned wall better in maintaining a smooth true surface over time? (Including foam panel insulating inbetween the frame members.)
If the answer to #2 is 'yes', then what is the MINIMAL size I should consider for the side walls. For example - 1/8 skin, 3/4 frame, 1/8 skin. (Like to keep it lite as well.)
Thanks in advance!!
Fred
Thanks in advance!!
Fred
