Page 1 of 2
Pics and ideas needed! Countertops please!
Posted:
Mon Jan 09, 2012 5:48 pm
by DavieBoot
Hi forum, I'm getting ready to build the kitchen area of a TTT that my boyfriend and I are building. I'm trying to find some ideas for counter tops.
Dose anybody have any lightweight counter top ideas? What works? What wears well and looks good?
Thanks!
Ashley
Posted:
Mon Jan 09, 2012 6:02 pm
by doug hodder
Any of the million patterns of formica or similar laminates on ply...about as light as you're going to get, wears well. Doug
Posted:
Mon Jan 09, 2012 6:11 pm
by StPatron
I agree with Doug's recommendation.
A little heavier but very durable... laminate flooring. I chose a tiled look laminate flooring, Habitat for Humanity find.
Posted:
Mon Jan 09, 2012 6:42 pm
by DavieBoot
Okay, so if I go with laminate I'm looking for something funky..maybe with a little sparkle, otherwise a bright color, like orange or red. Does anybody have any suggestions on any specific builds that have used bright laminates for the countertops so I could get a visual? If not that, anybody have suggestions for companies that make funky color laminates?
Thanks a tons!
Posted:
Mon Jan 09, 2012 7:34 pm
by StPatron
Laminate suppliers (including HD and Lowe's) have design catalogs and samples and will special order non-stock patterns.
Websites, such as Wilsonart, might help during your research:
http://samples.wilsonart.com/
Posted:
Mon Jan 09, 2012 7:55 pm
by hoytedow
The counter-top doesn't have to be heavy. I built mine out of 1/4" plywood. It holds the microwave just fine. It does have a 1.5" frame glued all the way around it so it will hold shape. You can then cover it with any spill-proof coating, even epoxy.
Posted:
Mon Jan 09, 2012 10:20 pm
by BrwBier
I built my counter top with laminate, 1/4" ply, 1"pink foam, 1/4 ply. All glued together. Nice and strong and some what light.
Brwbier
Posted:
Mon Jan 09, 2012 10:55 pm
by Juneaudave
If you haven't done so...the
Galley Galleryis a great place to get ideas!
Posted:
Tue Jan 10, 2012 3:24 pm
by Tumbleweed_Tex
Here’s an untested idea…
Flooring centers always have a box or two of leftover or discontinued hardwood flooring planks for little or nothing, and teardrop galley countertops are not very big.
A little experimenting with fine sandpaper, and you could paint these planks to your heart’s funky content.
Mix or clash the colors at will.
Then, instead of installing the planks parallel with the front of the countertop, put them down at a 30 or 35 degree angle, and take care to get the joints really tight. Once installed, a few coats of clear sealer would finish the job.
I’m not sure how this painted version would look, but I’ve seen the hardwood flooring used on countertops in a high-dollar motor coach conversion, and it was very impressive. The angled installation made it look really nice.
Posted:
Tue Jan 10, 2012 3:27 pm
by DavieBoot
Tumbleweed,
I like that idea a lot. I think I'll be calling some flooring stores this afternoon!
Posted:
Tue Jan 10, 2012 3:42 pm
by Tumbleweed_Tex
Pictures...lots of pictures...
I'm thinking the finish on that stuff will have to be roughed up a little with 220 or 320 grit to get the paint to stick well, and the face veneer is pretty thin. Be sure and paint the mating surfaces so there will be color in the joints.
Experiment a little, and keep us posted, because you're gonna be the subject matter expert.
Posted:
Tue Jan 10, 2012 3:48 pm
by DavieBoot
I'll be sure to let you know how it turns out!
Posted:
Tue Jan 10, 2012 4:15 pm
by gregp136
The red Formica worked for us.
Greg(and Laurie)
cork
Posted:
Tue Jan 10, 2012 4:23 pm
by DavieBoot
The flooring post got me thinking about cork. I found this on the interwebs.
http://soytuf.com/cork Anybody know anybody who has used cork? o
cork tiles
Posted:
Tue Jan 10, 2012 4:51 pm
by DavieBoot
I think I've changed directions totally in the last few minuets. I think I'm going to try cork floor tiles like this
http://laycock.smugmug.com/Other/Projec ... 73&k=Fs7u7
Along with hemp board for the under surface. Hemp board is super light and strong, and I just called the owner of this company
http://www.hempsteads.com/hemp-concretehemp-board/ and he said he has some second lying around that he'll sell me.
Now I'm REALLY excited. Thanks for the ideas...the flooring was a great idea..and the inspiration for the cork..I don't think you can get any lighter than cork!
