Forrest747 wrote:I have question about securing the roof. I plan on putting a bead of PL adhesive along the spars and wall joints. The spars are about every 12 inches or so. The roof is also flat from the front to the back. So i was wondering can I just screw it around the perimeter where the walls meet the roof. the roof will be 3/4 inch
jonw wrote: The only issue with this method is the potential for introducing leaks.
Good luck!
afreegreek wrote:that will work fine but you're better off putting some fasteners along your "spars" too at least until your adhesive cures.. after, you can take all the fasteners out if you want to as long as you got everything positioned before the adhesive skinned over.. a good bead of PL is 10x more than you need and the screws serve no purpose other than attracting moisture..
yup, that's the way to do it.. the extra battens are good.. they keep things in plane.. PL is thick and it's pretty easy to create undulations in the skin with screws alone.. self tapping screws are good, those look like TAPCON, but drywall screws well. they're designed to penetrate softwood lumber with no pre-drill and the shanks are thin with raised thread to prevent 'bridging'.. they're also very cheap.aggie79 wrote:afreegreek wrote:that will work fine but you're better off putting some fasteners along your "spars" too at least until your adhesive cures.. after, you can take all the fasteners out if you want to as long as you got everything positioned before the adhesive skinned over.. a good bead of PL is 10x more than you need and the screws serve no purpose other than attracting moisture..
That is how I fastened my 1/8" ply roof. For the screws, I used the self-drilling screws so I didn't have to drill pilot holes. The screws didn't fully penetrate the spars.
Since I was covering the roof (and sidewalls) with aluminum, I found it handy to mark the location of the spars and electrical runs on the plywood so I didn't put any fasteners where they didn't need to be.
After the PL Premium set, I removed the screws, and filled the holes.
Take care,
