Stainless steel skin
Postby egjacks » Sat Feb 18, 2012 3:20 pm
I was at the metal recycling place the other day, and they have 5x10 sheets of Stainless Steel in the scrap area for $1.00 a pound, I had them weigh a sheet for me and it came out almost exactly 60lbs. So $60.00 per sheet +/-... I don't know what grade it is, but by playing with a weight calculator, I think that it is probably .03 or 22gauge. This seems to be an amazing deal. I priced out NEW aluminum, 5x10 sheets and came up with about $160.00 per sheet.
I realize that SS will be over twice as heavy as the Aluminum, but I have been afraid I would have to give any metal skin a pass because of the price. I am towing with a Mazda B4000 (Ford Ranger) so I am not overly concerned with the weight.
what are the pros and cons of SS vs Aluminum? Like I said, I understand the weight difference, has anyone had either good or bad experiences with either SS or Aluminum skins(mostly SS)?
Eric
_________________
~If I fall flat on my face, at least I am moving forward.~
egjacks
Re: Stainless steel skin
Postby Wanna Be » Sat Feb 18, 2012 4:32 pm
HI !!
For the price you quoted, GRAB IT quick !!!!!!!!!!!!
S S won't dent as easley as aluminum will.
It can be polished if you want to and will stay brighter longer than aluminum.
To bad it isn't any closer to me, Cause I wouldent have left without as much as I needed !!!!!
Stay safe, and have fun !!
Wanna Be ;)
This nation will remain the land of the free only so long as it is the home of the brave.
~Elmer Davis
"Well, if you can't believe what you read in a comic book, what can you believe?" ~ Bullwinkle J. Moose
Also I am a professional spelling butcher.. I don't carry a dictionary and my spell check is broke!!
Wanna Be
Postby madjack » Sat Feb 18, 2012 5:48 pm
Wanna Be wrote:HI !!
Wanna Be ;)
...gotta agree with that!!!! It may be a tad harder to cut/work but shouldn't be too bad and for that price and since you are towing with a PU, I wouldn't worry about the weight penalty.....
Postby eamarquardt » Sat Feb 18, 2012 6:01 pm
Sounds like nice stuff. Some SSs though can be a real bear to cut and work with. I'd see if they'll let you make a test cut. I think I'd use a saber saw with a good bimetallic blade and some WD40 or even a water spray to keep the blade cool. It would be a real bummer to buy it and have it so difficult to cut that it makes your life miserable.
You may want to check out these guys: http://www.copperandbrass.com/cnb/index.htm
They are pretty competitive. There was/is a huge price break when you go over 100#. It was cheaper for me to buy five sheets of 5X12 .040 5052 than it was to buy 4 sheets. Go figure!
Hope this helps.
Gus
eamarquardt
Images: 150
Postby Wanna Be » Sat Feb 18, 2012 6:48 pm
eamarquardt wrote:Sounds like nice stuff. Some SSs though can be a real bear to cut and work with. I'd see if they'll let you make a test cut. I think I'd use a saber saw with a good bimetallic blade and some WD40 or even a water spray to keep the blade cool. It would be a real bummer to buy it and have it so difficult to cut that it makes your life miserable.
Hope this helps.
Gus
NO DO NOT USE WD40 !!!!! On Stainless Steel !!!!!!!!!
You WILL NOT like the results!!!! Use any cheep vegatable oil as a lube.
Ask any steel shop how much to cut it with a plasma cutter first!!
If the cost is prohibitive, then use a jigsaw with as quoted from above.
I know that most of the members are not as lucky as me,, But after working arround this stuff for years, I DO remember some stuff !!
For smoothing the edges, Use A flap type sanding disk for the best results.
FWIW; WD40 caused an explosion in my shop when used to cut Stainless Steel with, The flames from the fire wern't pretty.
Lynn,, Wanna Be ;)
~Elmer Davis
Wanna Be
Postby halfdome, Danny » Sat Feb 18, 2012 7:34 pm
Teardrop builder, Ed Ester of the Seattle area uses stainless steel for his roof skins.
It seems to stand up to bird poop and tree sap a lot better and doesn't oxidize like aluminum can.
Don't remember how he said he cut it but he does lap joints with butyl tape and stainless steel screws.
I did notice ( in indirect night light) on one of his galley hatches "J" roller marks, so it can dent some.:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby droid_ca » Sat Feb 18, 2012 8:45 pm
I personaly think it would be a good thing to have on your trailer it can be polished up nice and shiny is a heck of a lot stronger and if you wanted to you could electroplate it...thats just my 2cents
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby chorizon » Sat Feb 18, 2012 9:30 pm
droid_ca wrote:I personaly think it would be a good thing to have on your trailer it can be polished up nice and shiny is a heck of a lot stronger and if you wanted to you could electroplate it...thats just my 2cents
Cool! Who electroplates trailers clad in SS sheet?
I have a lot of work in mind for someone willing to take on a task of that magnitude... :twisted:
chorizon
Images: 94
Postby eamarquardt » Sat Feb 18, 2012 10:28 pm
Lynn,, Wanna Be ;)
Ya know, I've never had a problem with WD40. I, though, don't have to learn EVERYTHING first hand/the hard way. :lol: Water/soluble oil is a great coolant as the oil lubricates and the water is just about the best coolant out there as it vaporizes at a low 212F and carries away a lot of heat. Far more than oil as oil rarely get hot enough (in any quantity) to absorb heat by vaporizing. Thanks for the warning.
I'd still make a test cut. I wanted to install a transmission cooler in my Ford van. It must have some of that new fangled high strenght steel. A cobalt drill bit wouldn't touch it. As I remember I only had to "drill" two say 5/16" holes. I tried a solid carbide burr and it wouldn't touch it! Only a grinding stone would work and it took me a long time. I guess firefighters are having a tougher time rescuing people as they come across more of the high strength steel.
Gus
eamarquardt
Images: 150
Postby chorizon » Sat Feb 18, 2012 10:45 pm
Yeah, I'm with Gus on this one in that I haven't managed a major conflagration with WD40 yet...
That being said, I have used it several times as a "starter-fluid" on diesel engines.
Used to spray it directly into the turbocharger intake on the 'ol family Dodge when it was feeling pesky and she'd fire up like a gasoline engine on ether... :thinking:
I guess I'll stick with water-soluble oil in a squirt-bottle as well when cutting metal by hand...
chorizon
Images: 94
Postby droid_ca » Sun Feb 19, 2012 1:58 pm
Why what are your ideas, as I have 3 electroplaters...Just a hobby but I couldn't pass up on buying my industrial plater. I think that it will come in handy when I do my tiny house. I will be doing all the aluminum and chrome on my truck to accent it with gold plate, but you can do many other things copper, silver, chrome, ...just to name a few
“Fide Canem”
droid_ca
Images: 176
Postby egjacks » Mon Feb 20, 2012 9:08 pm
OK, I bit the proverbial bullet and went and bought the SS. Payed just over $400.00 for five sheets after taxes. Some people have nice big budgets, but that was an ouchy one for me. I am excited though. I think that it will look really good when I am done, and probably be WAY more waterproof than any other way of finishing the trailer than I could otherwise have come up with. I figure I have one sheet for each side, two for the roof, and one extra sheet for booboos and incidentals. If I manage to make no major or irreparable mistakes sheet number five will be for a nice tongue box or maybe part of the galley.
Eric
_________________
egjacks
Postby cpinetree » Sat Mar 03, 2012 7:27 pm
When drilling holes, try this trick: dip the bit into some sugar (plain granulated table sugar).
You will be amazed how easy stainless will drill. I know it works really well when using a holesaw in a Stainless electrical enclosure.
good luck, I am looking forward to pictures.
cpinetree
Images: 18
Postby Wanna Be » Sat Mar 03, 2012 8:10 pm
cpinetree wrote:When drilling holes, try this trick: dip the bit into some sugar (plain granulated table sugar).
Also something to note;
Slow the rotation,(speed) of the drill. Have PLENTY of sharp drillbits as they tend to dull quickly.
Stay safe, and have fun !!!
Wanna Be
P S Remember eye protection S.S. Is a trip to the DR's office if it happens
~Elmer Davis
Wanna Be
Postby KCStudly » Sat Mar 03, 2012 8:23 pm
Re: Keeping drill bits in tip top shape, don't drill with out http://www.drilldoctor.com/ :thumbsup:
Re: Eye protection, Plus 1. Doctor using a dremel tool to remove a chip from your eye :thumbdown: . I wear glasses all the time, including prescription safety glasses w/ side shields and I'm the only one on my street that I know of that wears a full face shield when operating the weed whacker! Still, I have at least a couple of extractions under my belt and to this day, whenever I get an eye check up, my eye doctor mumbles, "yup, there's that rust spot".
On at least two occassions I have gotten stuff in my eyes while taking a shower after dirty jobs (crud washes down from your hair and into your eyes), so I have learned to be careful until after I have washed my hair out well.
