Steel and wood fenders?
Postby StanDahl » Mon Mar 19, 2012 11:24 pm
I'm doing my trailer with enclosed wheels, do you think it's a worthwhile idea to have my chassis builder put steel fenders on the frame even if I'm going to cover them in wood, or is the roll on tar goop or window trim rubber stuff good enough by itself? I figure the steel will keep some of the water blast away from the joints in the wood fenders and prevent gravel from eroding my protective coating. It might also give something for the fender skirt to attach to.
They would be be either smoothly curved or flat on top with angled front and back sides and would be covered on the cabin side, open on the outside. I wonder if this design might allow water to pool above the fender and against the wood. Whaddaya think?
John
StanDahl
Re: Steel and wood fenders?
Postby linuxmanxxx » Tue Mar 20, 2012 7:58 am
I built one like that and just used 1x(xx) that fit the inside of the wheel well with the goop and it worked just fine.
linuxmanxxx
Images: 10
Postby doug hodder » Tue Mar 20, 2012 9:00 am
On the Nomad, wood wheel wells...I coated them well with epoxy and glass cloth...then shot it all with a heavy coat of automotive undercoating. Doug
Postby 48Rob » Tue Mar 20, 2012 11:53 am
Mine are wood, sealed with oil based paint, and covered in undercoating.
Adding metal would help, but then you stand a chance moisture would get between the wood and metal, which is bad.
If you could embed the metal in a coating on the wood, it might work.
Rob
48Rob
Postby Wobbly Wheels » Wed Mar 21, 2012 8:53 am
Mine are enclosed as well, being built on a tent trailer frame. I'm building wood boxes and putting chamfer strips in the corners because, on the last one, mud packed into the corners and held moisture. I'll be sealing the wood with PU and using spray-on bedliner to line it.
Wobbly Wheels
Postby terryjones1 » Wed Mar 21, 2012 8:59 am
doug hodder wrote:On the Nomad, wood wheel wells...I coated them well with epoxy and glass cloth...then shot it all with a heavy coat of automotive undercoating. Doug
I did the same thing, except I painted using thick truck bed coating.
My TTT Garageable Standy Build Journal: viewtopic.php?f=50&t=40591
terryjones1
Postby StanDahl » Fri Mar 23, 2012 8:01 am
Okay, It looks like I can save myself some money and go with wood. Thanks!
John
StanDahl
