Fastener spacing in plywood skin ?
I'm fast approaching the time to skin my weekender. I plan to use 3/8" plywood glued and screwed. I will have lots of screws around the edges of each panel, but how often should I screw out in the center. I want to keep the hole patching in the center to a minimum.
Spar spacing is 12" or less (on edge) and I will glue the entire length of each spar and around all edges. The final finish will consist of fiberglassing of all joints and breaks, CPES primer throughout, and a West system boat paint.
