Harbor Freight Stamping Set: Product review
My trailer registration process required that I stamp the state issued VIN numbers onto the frame. I was a bit leery of the results I would obtain using the Harbor Freight stamping set but for a bit over 6 bucks w/coupon decided I'd give it a try.
I used a hand-held sledge hammer and gave each stamp 6 solid hits. I was pleased with the results.
If you're needing to stamp numbers or letters onto steel, this set will do the job.
(The angle of the lighting tricks the eye, the stampings appear raised. They're not, they're stamped into the metal.)
