Take a look at O'Shell's "Standy Widget" build here
http://www.tnttt.com/viewtopic.php?f=50&t=50100. He started out with a big dbl axle TT frame that needed some work and I have given him a bunch of welding advice on his thread. He has some welding training in his background and a suitable welding machine for the task.
90 amps is probably not enough to properly weld the gauges that are needed for a proper trailer frame. And I'm not a big fan of flux core (unless it is windy...even then, not so much). If you are stringing your welder out to your work area with a long skinny extension cord, that will wreak havoc on your ability to weld. You may also be running up against the duty cycle of your machine. The inexpensive entry level welding machines have dismal duty cycles (the time that you can weld versus the time that the machine needs to recover inbetween welding).
Another thing, If you are able to pull any of your welds apart by hand (except for little itty bitty one sided tacks) then your other welds are also very suspect. Just because you can't pull them apart by hand does not mean that they are up to the task of sustaining even modest loads in service. A loaded trailer bouncing down the road sees a lot more dynamic load than you could ever hope to apply by hand...even with a lever.
Make an honest assessment of your welding ability, both personal and equipment wise. If you really want to do it yourself, seek out more training, practice on scrap, and consider an equipment upgrade. If you just want to get it done and over with for a minimum of money and time outlaid, it sounds to me like you should be considering the services of someone with more experience.
Please don't be offended. I am not trying to discourage you. I have yours and other's best interest in mind. You will never be happy and will always be worried about immanent failure if you are not 100% confident in your work. You can thank me later after you have had time to think it over.
